Tip & How-To about Computers & Internet
How do I read barcodes from an Adobe PDF FILE?
Reading a bar code in a portable document format (PDF) document is a simple procedure. Some newer phones come with smart barcode scanners, and you can scan the Internet to buy. A barcode is a series of lines of code that identifies a product. When you print the document with a single piece of technology, you can read a barcode in a PDF document.
1. Open the PDF document. Adobe Reader PDF reader is the most common. If you do not have Adobe, download the latest version of the company's website for free download (see Resources).
2. Select "File" drop-down box to the left of Adobe. Select "Print" and then "OK".
3. Set the bar code scanner. Jumping the gun and a horizontal red line is designed with the focus of the scanner. Move the line through the barcode printed on the document until the scanner beeps. Release the trigger and see the screen on the back of the scanner, which will give you the information encoded in bar code.
4. Download a barcode scanning application for your smart phone if you do not want a handheld scanner. Most bar code applications are free. Open the program and point the camera at the barcode in the PDF. Wait until the camera for a snapshot of the barcode will not make up the barcode in the light of the entire camera to take. The program will decode the barcode and display the results.
Computers & Internet Logo
tab key configuration
manual can be found at http://www.opticonusa.com/pdf/Manuals/Universal_Menu_Book.pdf on page 104 (U97) scan the "set" bar code followed by the "Tab" bar code and then on the "End" barcode
Mar 16, 2013 | Opticon OPR 3201 Barcode Scanner
HOW DO I RESET A CORDLESS SCANNER HONEYWELL 3820?
I believe you can print the documentation and scan a bar code to reset the scanner. You can get the documentation here: http://lib.store.yahoo.net/lib/barcodescannersdiscount/3820UserGuide.pdf
Press CTRL+F and type "reset" to find sections on resetting the scanner.
Mar 02, 2011 | Honeywell 3820 Wireless Handheld Barcode...
what it`s that?
A barcode scanner is normally a program that will use your camera on your PC to scan a barcode, either a QR code or product bar codes and some may even show best prices online for the item scanned. These scanners are popular on portable devices such as android phones and iphones.
Feb 28, 2011 | Computers & Internet
I can't programmed my IT3800LR
Jaquino, there is a programming bar code to reset the device to factory settings in the user guide. I know you said that it is reading other bar codes like they are not programming bar codes, but have you tried this bar code? Usually it works, even when the device is totally hosed, unless there is some kind of hardware failure.
Here's the link to the Quick Start from the company website:
http://www.handheld.com/download.aspx?download=/data/f9e7f996-9ecc-4f49-b604-32fbd754085d.pdf&filename=3800+Linear+Series+Quick+Start
The factory reset bar code is on printed page 4 of the PDF document.
Mar 05, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
1,991 people viewed this tip
David Payne
David Payne
