Tip & How-To about Computers & Internet
How do I make Barcodes Online?
The best-known lines from the supermarket, bar codes are graphical representations of data that a computer using an optical sensor can read. There are many ways to encrypt data barcodes, such as the width and number of parallel lines or representations of 2D points and squares, which are still being considered as a bar code. Encryption of data in bar code symbols that would be very difficult, but fortunately there are many free tools online for encoding data in barcodes. These online resources are simple and you can print a barcode on a product to sell or an object just for fun. For example, you can use your name in bar code format!
Instructions using Soft Barcode
1. Visit Online Barcode Generator Bar Code Soft. Unlike some barcode generator online, such as the Vespa, the generator you select the file type of the barcode is generated within
2. Choose the desired settings for your bar code, including the width of lines, the symbolism - or Code 128, Code 11, Code 25 and many other options - and the bar width and height. These settings determine to some extent, the size of the barcode will be generated in order to keep in mind that your bar will. An object the size of a skateboard can also be larger than the institutions of an object like a watch, for example.
3. Enter the data you want the generator to encrypt. This information can include letters, numbers and special characters.
4. Please read the disclaimer, you agree to the terms and conditions and press the "Generate". Save the generated barcode by right-clicking on the image and the file name and location to be stored.
Wasp using instructions
1. Wasp Barcode Generator visits the Resources section.
2. Follow the prompts to choose a barcode symbology from the drop-down, data is encrypted and your e-mail.
3. Choose whether you want the barcode to be sent to your e-mail or to generate an image in the window. If the image is sent to your email, you are good, when closing the window on page generator barcode will lose the image file and force it to regenerate.
Instructions for Terry Burton Barcode Generator
1. Visit Terry Burton Barcode Generator in the Resources section.
2. Select the barcode symbology you want the code to generate 128 inches, for example, parallel lines familiar in supermarkets.
3. Clean fill the text "0123456" and enter the data you want the generator to encrypt. Changing the height of the text, if you want the parameter to adjust. The height of the text determines the appearance of text in the generated barcode. Click the "Options Reference" link to read more adjustments, such as ink and fountain.
4. Click the "Make Bar Code" button and wait for the new barcode will be generated. Click on any of the links file, such as BMP or JPEG format, the captured image to download to your computer.
Computers & Internet Logo
explain bar codes
A bar code (often seen as a single word, barcode) is the small image of lines (bars) and spaces that is affixed to retail store items, identification cards, and postal mail to identify a particular product number, person, or location. The code uses a sequence of vertical bars and spaces to represent numbers and other symbols. A bar code symbol typically consists of five parts: a quiet zone, a start character, data characters (including an optional check character), a stop character, and another quiet zone.
A BarCode Readeris used to read the code. The reader uses a laser beam that is sensitive to the reflections from the line and space thickness and variation. The reader translates the reflected light into digital data that is transferred to a computer for immediate action or storage. Bar codes and readers are most often seen in supermarkets and retail stores, but a large number of different uses have been found for them. They are also used to take inventory in retail stores; to check out books from a library; to track manufacturing and shipping movement; to sign in on a job; to identify hospital patients; and to tabulate the results of direct mail marketing returns. Very small bar codes have been used to tag honey bees used in research. Readers may be attached to a computer (as they often are in retail store settings) or separate and portable, in which case they store the data they read until it can be fed into a computer.
There is no one standard bar code; instead, there are several different bar code standards called symbologies that serve different uses, industries, or geographic needs. Since 1973, the Uniform Product Code (UPC), regulated by the Uniform Code Council, an industry organization, has provided a standard bar code used by most retail stores. The European Article Numbering system (EAN), developed by Joe Woodland, the inventor of the first bar code system, allows for an extra pair of digits and is becoming widely used. POSTNET is the standard bar code used in the United States for ZIP codes in bulk mailing. The following table summarizes the most common bar code standards.
Mar 09, 2014 | Computers & Internet
2,595 people viewed this tip
David Payne
David Payne
