Tip & How-To about Computers & Internet
How do I Register a Barcode scanner
In general, all manufacturers provide information on the registration of their products. By registering your barcode scanner, allows easy access to guarantees, technical support and maintenance and notification of product announcements, updates and offers. The record provides a record in case you need a replacement due to theft or damage. In return, the company your personal information to send you announcements and discounts on your scanner and other products they sell.
1. Go to the manufacturer's website. Determine if the barcode scanner to register online or to install the necessary drivers and the registration process. If not, connect the barcode scanner to your computer via the USB cable.
2. Turn the scanner installation CD into your CD-ROM. Please wait while your computer loads the driver installation wizard. Follow the wizard and install the software. A window will open asking if you want the scanner to register. Select "Yes" and wait while your web browser opens to the registration website.
3. Enter the information requested on the on-line application. The typical form requires your name, e-mail, model and serial number of the scanner. Also, some require a product key or registration.
4. Click the Send button to send your information and complete the registration process.
Computers & Internet Logo
Want to register a krupsusa toaster I bought yesterday
If you don't wantto register online, can you put the card that came with the toaster in the mail?
Jun 04, 2014 | Toaster Ovens
code activation
WinZip is a file compression utility that allows users to "zip" files into archives that have significantly smaller file sizes than the original files.
If you purchase WinZip directly from the WinZip website, a registration code is sent to you via email that allows the software to be used as soon as it is installed.
If you purchased the program from a third-party retailer, however, you must use an activation code to activate and register the software. Launch the WinZip program.
A screen will appear, reminding you to register your product and giving you the option to enter your name and registration information.
Enter your name where prompted.
Enter the activation code that came with your WinZip installation disc or in the activation information email you received when you purchased the product.
Click the "Register" button.
Enter all required information when the WinZip Activation Information screen appears.
This screen collects the information that WinZip Computing needs to properly register and activate your software.
Click the "OK" button to submit your information.
The WinZip software will transmit your information to WinZip Computing's activation server, registering your software with the company and receiving a registration number that it will use to activate your copy of WinZip.
Check the email address you entered when activating your copy of WinZip.
A copy of the registration information will be sent to you, including the registration number that was used to activate your software.
If you need to reinstall WinZip in the future, use the registration number instead of the activation code.
or
Its illegal for anyone to provide serial keys for programs that have retail values set on them there are freeware alternatives on the internet.
ZipGenius is a FREEWARE product
http://www.zipgenius.com/index.php?id=33
ZipGenius can handle more than .zip or .rar file
20 compressed archive types.
http://securezip-express-for-windows.soft32.com/
Free zip
http://www.all-freeware.com/details/154438/1-click-unzip-.html
http://en.softonic.com/s/winzip-8-freeware
Sep 26, 2013 | WinZip 12.0 - Windows for PC
registring nuvi
Hello there,
To register your garmin nuvi click on the link below: https://my.garmin.com/mygarmin/marketing/register.htm
To register your Garmin device, please visit the Garmin registration page online. To begin, select the type of product you wish to register then follow these easy steps based upon the product selected: Automotive devices: Sign in to your existing myGarmin account or select the option to create a new account (if one has not already been created)1 If prompted, select Continue on the page titled "Getting Started" Connect your device to your computer Follow the steps to install the Garmin Communicator Plugin2 Confirm the device information is correct and select Continue If you created a new myGarmin account, enter the required information and select Next (this step is skipped if using an existing account) Your device is now registered in your myGarmin account. Information on your device and possible updates will be provided on the Registration Complete page.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin nuvi 255W GPS Receiver
its does not have a cd-rom... the usb doesnt work why? is the usb 2.0 already?
More information is required to provide a thorough solution to your problem. Here is a general solution based on what you have said.
First, unplug the barcode scanner from your computer. Next, go to the website of the barcode scanner's manufacturer. If you do not know the website, search for the manufacturer on Google or another search engine.
Once you've found the manufacturer's website, look for a "support" section. Often times, you will likely be prompted to select the product you're seeking support for, either by clicking it from a list or typing in the product's item number.
After identifying your model, you should be taken to a support page specifically dedicated to your device. Look for a "downloads" or "drivers" link or section. Download any software provided on the site, making sure to select the one compatible with your operating system.
Launch the downloaded file and follow any on-screen instructions to Install the software. You may be prompted to restart your computer once installation completes. If so, go ahead and restart your computer. After you restart (or after the install completes, if no restart is required), plug in your barcode scanner. Your computer should recognize the new hardware (assuming it is "plug-n-play," as most USB devices are) and begin installing the drivers automatically.
If you locate and install the relevant software, but this solution still does not work, try using a different USB port.
If you cannot locate any installation software on the internet, you should contact the retailer from whom you bought the barcode scanner.
Jun 14, 2011 | Computers & Internet
I would like to register my new Garmin navigation 1450LMT show me how
From Garmin site; to register your Garmin device, please visit the Garmin registration page online. To begin, select the type of product you wish to register then follow these easy steps based upon the product selected:
Automotive devices:
Outdoor, Fitness, Sport, Marine and other devices:
Login to your existing myGarmin account or select the option to create a new account (if one has not already been created)1
Enter your device serial number3
Select Submit
Confirm the product name and serial number are correct and select Next
Your device is now registered in your myGarmin account. Select the option to Go to myDashboard to check for device firmware updates.
1 Multiple devices can be registered in a single myGarmin account.
2 The Garmin Communicator Plugin allows your device to communicate with your computer. If you are registering multiple devices, you will skip this step once it is installed. For browser specific instruction on installing the Communicator Plugin, click here.
3 The marine device registration path also provides an option to register using the device unit ID as well as an option to register using a prepared card.
Note: For instructions on registering your nuvifone or garminfone, click here.
Hope this helps.
Jun 06, 2011 | GPS
230 people viewed this tip
David Payne
David Payne
