Tip & How-To about Computers & Internet
How do I create custom Barcodes?
Barcodes can be printed symbols with encoded data will be charged to the computer via a scanner. A bar code allows a company to maintain control of their actions to secure and instant access to information about each product. A bar code is created using software barcode generation software. Customizing a bar code is a simple process to enter your data into the software program, and print.
1. Open your Web browser and visit Barcode Generator, barcode or Soft. See the program's interface is usually presented on the homepage of the website page. Look at the list of different types of bar codes available, and click the type of barcode you want to use.
2. Locate the area where you are allowed to present the information is converted into a bar in, and within the data type. Click "Generate Barcode" to create barcode images. View the image resulting bar code, right click on the image and click "Save image as" in the drop-down menu to save the resulting image on your computer.
3. Close the program bar code generation, and open the bar code image stored on your computer. Right click on the saved image and click "Print" from the output drop-down menu to print the bar code. Scan the bar code information printed to be loaded on your computer and check the data sent to make sure it is correct.
Computers & Internet Logo
how to program a bar code scanner to have 2 Tilde in prefix
Hi, to program two tiles before the data you must use Advanced Data Formatting bar codes from the LS2208 Product Reference Guide. You will need to print and scan the following barcodes:
Begin new rule
Send tilde
Send tilde
Send all data that remains
Send enter key (if you need an enter after the data )
Save rule
Go to the Motorola Solutiond Support Portal and search for LS2208 PRG. The guide has also been stored on Fixya.com
Sep 12, 2014 | Symbol LS2208 Handheld
How do I disregard the last character on a UPC bar code?
In general you can create an Advanced Data Programming Rule which will say: If you scan an UPC barcode, please send only the first 11 characters of the barcode.
There are programming barcodes in the manual for the scanner or you can use the 123Scan2 application provided at support.symbol.com to create the rule and print out an config sheet.
Aug 26, 2010 | Symbol LS2208 Handheld
233 people viewed this tip
David Payne
David Payne
