Tip & How-To about Computers & Internet
How do you make a Bluetooth Antenna?
"Everything is better with Bluetooth" is an adage that was popularized by the television program "The Big Bang Theory. It's hard to argue with that. Bluetooth is a fast and secure way to transfer digital information. While it is useful can extend the range a Bluetooth connection, making your own antenna to make technology more valuable.
1. Pry apart the case with a Bluetooth screwdriver. Remove the electronics module.
2. Heat the existing antenna cable with a soldering iron and pull it free from the oscillator.
3. Remove the excess solder the electronics module using a disordering braid.
4. Remove the outer insulation of the new antenna cable, and cut the outer shield of the coax to the wire strippers. Add a little solder to the shield for the more solid.
5. Exposing the central thread of removing the cable from 1 / 2 inches. Leave a bit of plastic between the wire and shield.
6. Slide the wire through the hole and bend it at right angles. The shield should be established by the turtle.
7. Protect the solder and pad together. Turn the plate over the center wire and solder in the hole. Remove any excess wire with wire cutters.
8. Clip the excess wire stabbing through the hole and insert the module in the case and assemble the two halves. Use tie-tape, glue or tape to hold it together when necessary.
9. Insert the module on the subject and put things back. Use clamps to hold it together.
Computers & Internet Logo
Is big bang theory on its last season?
Is The Big Bang Theory Ending After Season 10? ' E! News Canada
www.eonline.com/ca/news/769983/is-the-big-bang-theory-ending-after-season-10
  1. Cached
Jun 3, 2016 - Star Kunal Nayyar hinted the CBS sitcom will end its run on CBS in 2017 ... We Need to Talk About The Big Bang Theory Season 9 Finale's ...
'Big Bang Theory': Will Season 10 Be Its Last? ' Hollywood Reporter
www.hollywoodreporter.com/live-feed/big-bang-theory-will-season-843830
  1. Cached
  2. Similar
Dec 21, 2015 - In its ninth season, CBS' The Big Bang Theory continues to check off major milestones. The season opened with Leonard (Johnny Galecki) and ...
Will The Big Bang Theory Continue After Season 10? Here's What ...
www.cinemablend.com/.../Big-Bang-Theory-Continue-Season-10-Here-What-Kunal-...
  1. Cached
  2. Similar
The Big Bang Theory has experienced continuous success ever since the CBS sitcom premiered back in 2007. The show is currently going strong on its ninth season, with a guaranteed tenth on the way next year.
'The Big Bang Theory': Will the Series End After Season 10?
www.cheatsheet.com/.../the-big-bang-theory-will-the-series-end-after-season-10.html/...
  1. Cached
  2. Similar
Sep 18, 2016 - 'The Big Bang Theory' is currently greenlit through season 10, but will that ... When asked if he's plotting out season 10 as if it's the final season, ...
'The Big Bang Theory' Season 10: What We Know So Far
www.cheatsheet.com/entertainment/big-bang-theory-season-10-know-far.html/?a...
  1. Cached
Sep 18, 2016 - The Big Bang Theory's Season 9 finale ended with a surprising ... It's something he has in common with Sheldon's mother Mary (Laurie Metcalf) ...
'Big Bang Theory' signals Season 10 won't be its last - USA Today
www.usatoday.com/story/life/tv/2016/.../big-bang-theory...season...its-last/90843926/
  1. Cached
Sep 25, 2016 - BURBANK, Calif. - Over the past nine seasons,The Big Bang Theory pals have found relationships, marriage and even impending ...
The Big Bang Theory - Wikipedia
https://en.wikipedia.org/wiki/The_Big_Bang_Theory
  1. Cached
  2. Similar
The Big Bang Theory is an American television sitcom created by Chuck Lorre and Bill Prady, ... They brought in the remaining cast and retooled the show to its final format. Katie was ...... By the end of the 2012-13 television season, The Big Bang Theory had dethroned Judge Judy as the ratings leader in all of syndicated ... Is big bang theory on its last season Google Search
Nov 15, 2016 | Cars & Trucks
Does anyone know what Sheldon's political views are? I have a hard time pinning him down, but I know he does have them.
Ok. So, he'd be against stuff like immigration, welfare and gay marriage? Although, I'd imagine he'd be reactionary against his parents, considering how he is with religion.
Sep 04, 2016 | The Big Bang Theory (2007)
station preset
If I have the same one; all you need to do is tune into the station you want to listen to. Then tap and hold on the preset you want to program it to. You will then see the p1 -p6 icon, which ever one you are programing will light up to indicate that you have set it. Its a little hard to see but if you have finger nails, the radio responds better. So in theory use a stylis when doing this it will be easier and much better to see.
Feb 02, 2014 | Ouku 7 Inch Car Stereo Radio Dvd Player In...
422 people viewed this tip
David Payne
David Payne
