Tip & How-To about Cell Phones
How can I reset Bluetooth Password?
When you connect two Bluetooth devices, you enter a code on both devices. Sometimes the code indicates an error and you are unable to both devices. To connect them again, you have the existing password to a different set of reset.
1. Accessing the menu of your phone and select "Bluetooth" option "Settings". Here are the devices that are currently connected to the phone. You want the password to restart the computer, click the Bluetooth icon in the taskbar tray of your computer. The list of paired devices is visible to you.
2. Select the device to which the password reset. If you restart your phone, there will be a "Delete / Reset PIN." If the option is not available, just "remove" the device from the phone. If you reset the password on your computer, right click the device icon and select Delete.
3. Re-connecting the two devices. You will be prompted to set a new password on both devices before a connection can be established. Set the new password.
Cell Phones Logo
how to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Jul 20, 2010 | Plantronics Explorer 330 Headset
i have nokia bh-100 bluetooth headset, i tried alot to connect with my cell as well as my laptop but i m unable to connect as while paring search the headset dont show the visibilty.kindly assist
Start with the headset turned off, and the bluetooth radio of the device you want to pair the headset to, turned on. Then, press and hold the headset's power button until the led flashes rapidly. It is indicating is in pairing mode. Now, make your device search for new devices, and select the BH-100 from the list. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
If your headset's user guide happens to be missing, download it from this location, if you want.
Hope it works for you.
Cheers! Carlos
May 10, 2010 | Nokia BH-100 Bluetooth Headset
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
unable to pair with my BMW X5 , 2005 bluetooth.No
You need to put the car in discovery mode and it should display a passkey, then use the phone to find the car and enter the pin code shown.
Oct 29, 2009 | Motorola Mobility CLIQ Cell Phone
286 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
