Tip & How-To about Cell Phones
How can I reset a Bluetooth?
Using a Bluetooth device for mobile phone or computer, it asks for a PIN or security code. The connection between two Bluetooth devices is based on this code. If you're not interested in connecting both devices in the future, you need the code again. On reset the Bluetooth devices to remove the existing code and will prompt you to enter in case you decide to return to be switched.
1. Go to the menu on your mobile phone. Find the connection options and select the "Bluetooth" option. In the Bluetooth menu, you can see the devices currently associated with the phone.
2. Use the arrow keys of the phone to disconnect the device you want to select. You will see a number of options from the context menu. Choose "Remove / Reset PIN." This will switch back to the default security code, usually '0000 '.
3. Disconnect the connection of Bluetooth devices; simply select the 'Delete' / 'Remove' option on your mobile phone. When you pair the devices in the future you will be writing a new code.
Cell Phones Logo
tell me how to connect internet from mobile i009 to bluetooth?
At first call to your customer care executive to send you for internet settings for your mobile. When you recive the settings then do the following things-
  • Install the settings first.-go to your message inbox and find the settings message when you open it then get the install option. Just click on install option.
  • Select your internet profile-just go to your internet menu and select settings. After that select Internet Profile and select GPRS option like Airtel Gprs/ Mobile Office if you are Airtel user.
After that Install Pc-Suite and
  1. Activate Bluetooth on your mobile phone (usually found under the Settings menu) and set it to be discoverable or visible.
  2. On the PC, find your Bluetooth program manager (in Windows XP and Windows 7, look under My Computer > My Bluetooth Connections; in Vista, look for Bluetooth devices in the Control Panel; on a Mac, go to System Settings > Bluetooth).
  3. In the Bluetooth program, select the option to add a new connection or device, which will make the computer search for available Bluetooth devices and find your phone.
  4. When your mobile phone appears, select it to connect/pair it to your laptop.
  5. If prompted for a PIN code, try 0000 or 1234 and enter it on both the mobile device when prompted and your laptop.
  6. When the phone has been added, you will be asked what service to use. Choose PAN (Personal Area Network). You should then have a working Internet connection.
May 18, 2011 | Computers & Internet
i have purchased a used GT-B3410 Model when i am connecting it through Blue tooth it asks for the security password which i don,t know . please help me
The bluetooth pin number is actually just to make sure both sides enter the same code. If for example, you're trying to connect to your computer, try using 1234 on each device. Or 0000, or whatever number you like.
Certain devices like bluetooth headsets will specify a code to use. Almost always 0000 or 1111.
May 05, 2011 | Samsung B3410 Cell Phone
I have a bluetooth plug-in handsfree car kit model#bthf0082 it asks for 4 digit pin on mobile when i try to connect device?
HI, TRY CODE 8888 ON YOUR MOBILE PHONE TO CONNECT THIS BLUETOOTH DEVICE BTHF0082. HABIB
Mar 09, 2011 | Cell Phones
how to connect samsung tocco mobile to another samsung tocco mobile using bluetooth?
Turn on the Bluetooth wireless feature.
To turn on the Bluetooth follow the below steps,
1. In Menu mode, select Applications > Bluetooth.
2.. Select the circle in the center to turn on the Bluetooth wireless feature.
3.. To allow other devices to locate your phone, select Settings > On under My phone’s visibility > Save.
To connect other device to your mobile
1. In Menu mode, select Applications Bluetooth Search.
2. Select and drag a device icon into the centre.
3. Enter a PIN for the Bluetooth wireless feature or the other device’s Bluetooth PIN, if it has one, and select OK.
When the owner of the other device enters the same PIN or accepts the connection, pairing is complete.
After connecting you can start sending the files from one mobile to another mobile.
To send files follow the below steps.
1. Select the file or item from one of your phone’s applications that you want to send.
2. Select Send via or Send URL via Bluetooth, or select More Send via Bluetooth
Thank You
Aug 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
237 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
