Tip & How-To about Cell Phones
How to connect Bluetooth GPS using mobile phone
Once I explain how Bluetooth GPS receiver to connect from a mobile phone. Bluetooth GPS Receiver is a device that continuously transmits its position (longitude, latitude and speed) using the Bluetooth protocol. If your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS receiver to determine its position. To locate, connect to Bluetooth GPS and mobile phone to get the NMEA sentences for location tracking, you can also program a Java (J2ME) for your phone. Your program should do the following tasks:
1. Bluetooth device within the search area. Each time a Bluetooth device is discovered, discovery listener device Discovered trigger procedure. In the search is completed, the trigger listener discovery process inquiry Completed.
2. Get the name Bluetooth. We have a choice to a group list of Bluetooth-friendly name of the devices found to store. We also need a vector to devices found to store.
3. Select Bluetooth GPS receiver from the list of found devices.
4. Find service by the GPS device. Bluetooth GPS Receiver provides an L2CAP service so that the program needs to find this service for GPS url connection string for.
5. Get connection string from the GPS device. Connection string to the URL will have this format Url = "btspp: Address / bluetooth /:" + + L2CAP_UUID "permission = false; encrypt = false";
6. Sign up and receive sentences from the GPS device. After plugging in the url in step 5, you can open the connection and extract sentences from the connection string.
Cell Phones Logo
I cannot connect any more to my motorola rasor phone, after I updated maps
If you can't connect your navigation device to your mobile phone try the following:
  1. Make sure you have the latest application installed on your navigation device.
  2. On your mobile phone, remove all Bluetooth bondings.
  3. If possible, remove the battery from your mobile phone for a few seconds, then re-insert the battery.
  4. Turn your phone back on and make sure that Bluetooth is enabled and that the phone is discoverable for other devices.
  5. You can establish a Bluetooth connection between your navigation device and your phone.
    The method used depends on the type of navigation device you have:
    GO 1000 series, Via series, Sony XNV GO x50, GO x40, GO x30, GO x20, GO x10
    Blue&Me TomTom, Carminat TomTom
    DAIHATSU, ECLIPSE, TOYOTA, MAZDA
    Rider
Mar 28, 2011 | Tomtom GO 910 GPS Receiver
Tomtom GO 720 mobile phone connection
Have you used yout Tomtom with other phones before?
Apr 12, 2008 | Tomtom GO 720 GPS Receiver
How do I turn the Bluetooth on to use with my I phone
Turn on your Nuvi, go to Tools in the next screen you should see Bluetooth..... go to Connections and Add Device
Once added make sure Bluetooth says Enable
Oct 19, 2010 | Garmin nuvi 205W GPS Receiver
how to connect phone bluetooth to tomtom
First enable bluetooth function under the menu options. (if not bluetooth menu button is seen you will need to tap the "show all menu buttons" button in the menu)
once bluetooth is enabled follow the prompts that the One XL gives you to connect device.
Please make sure your device is in discoverable mode (blinking blue and red) during the process.
Oct 16, 2010 | Tomtom One XL GPS Receiver
Mobile XT not excepting my GPS Receiver
Garmin will work with ANY windows mobile device with built in GPS and or a bluetooth receiver. But you have to have the correct software there are 2 versions both will install but only one will work with your model phone for older model phones use version 4.10 or lower for newer model phones use version 5.0 or higher.
Let windows manage your GPS ports do not try to set it manually. If you have a GPS fix option...go out side where you can get a satellite fix easily...launch your GPS fix program...thenlaunch Garmin. It should connect and you will have to do this only once. I know from experience and I've use this on a T-Mobile Dash with a bluetooh adapter with no issues. I'd try a different receiver preferably any Pharos GPS receiver.
Dec 31, 2007 | Palm Treo 700w Smartphone
499 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
