Tip & How-To about Televison & Video
How to Select a Bluetooth keyboard to purchase
With a Bluetooth keyboard, you have a multipurpose tool that connects and exchanges information with its other mobile devices such as a laptop or a personal digital assistant. Bluetooth technology has exploded in recent years, especially in the field of keyboards. To read about the right information to help you shop and make sure you have the Bluetooth keyboard suitable for your choice.
1. Determine a budget for your Bluetooth keyboard. Most models fall into the range of $ 50 to $ 150. The more expensive ones tend to be thin and light design, in connection with extras such as scrolling faster and longer lasting Li-Ion.
2. Choosing between Microsoft and Logitech marks for the widest variety of models, including special ergonomic Bluetooth keyboard. Logitech, for example, makes the Cordless Desktop Wave, while Microsoft is the Natural Wireless Ergonomic Desktop 7000. Stocks TigerDirect.com both brands (see Resources below).
3. Select the Bluetooth keyboard from Apple if you have a Mac to use it, you should work with OSX 10.4.10 or higher. You can buy directly through the Apple Store (see Resources below).
4. Select a portable Bluetooth keyboard when you buy for use with a handheld device like a Blackberry. For example, the iGo Stowaway Ultra-Slim Keyboard weighs only 6 grams. and folds to a size of 5.5 by 4 by 0.5 cm. Blackberry Bluetooth Keyboard weighs one gram. and pay more for a similar size.
5. Make sure your laptop or a Bluetooth adapter. Most laptops are designed with internal adapters, but some computers, an external Bluetooth dongle, a small piece of hardware that can connect to a USB port.
6. Consider selecting a Bluetooth keyboard that comes with another device like a mouse. Many companies such as Dell, offer these packages at discounted prices on their websites (see Resources below).
7. Inspect the return policy on the keyboard that you select. Make sure that you will be able to return or exchange your phone in case of problems.
Televison & Video Logo
bluetooth? How? Where?
Activate the Bluetooth functions of your Compaq laptop to connect your computer to external devices such as mice, keyboards and smartphones without the aid of a wire. Bluetooth technology allows devices from different manufacturers to exchange data, communicate and share files despite differences in operating software. Bluetooth antennae can cause a significant battery drain, so they are usually turned off by default. Turn on your Bluetooth to start searching for available devices in range of your computer.
Click "Start" and type "wireless" into the "Start Search" field. Click the "HP Wireless Assistant" icon in the list of results. Click the "Turn ON" button in the "Bluetooth" section to activate the Bluetooth antenna for your Compaq laptop.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065493&lc=en&dlc=en&cc=us&product=434626 - DeviceOn
Jan 20, 2013 | Compaq Presario CQ57-339WM
bluetooth cannot detect any bluetooth device
Normally, two Bluetooth devices must be paired before they can exchange data. The term pairing usually means that two devices are exchanging protected passkeys. Once paired, all information sent over the Bluetooth link is encrypted and will only be able to reach devices that are authorized to do so by the pairing process. In certain instances it may not be necessary to conduct the pairing procedure. For example, when exchanging business cards between two mobile phones it may be too cumbersome to pair with a password. Usually there is a setting in the device, in which you can set a lower level of security.
Dec 15, 2010 | Cell Phones
i cant enable my bluetooth device in windows 7 im using acer aspire 4920
check if u have bluetooth drivers installed...go to start n type bluetooth....ull get a list n click bluetooth devices.....if it opens....there might be bluetooth symbol key on ur keyboard(it will be to left of ur keyboard 4th button)...try clickin it..n then try connecting with ur mobile......hope this helps....
Mar 08, 2010 | Acer Computers & Internet
Bluetooth config
You can enable it by hitting your windows button on the bottom left of your keyboard and then hitting control panel. From there, go the the blue icon that says bluetooth.
Sep 21, 2009 | Computers & Internet
cannot connect to motorola phone tools using bluetooth
in the phone itself, you have to search for bluetooth devices and accept the found device in order for it to work, once set-up searching is not needed for that device again
Feb 12, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
2,799 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
