Tip & How-To about Computers & Internet
How to Fix a Bluetooth Dongle in a computer
Bluetooth devices connected to a computer system via a wireless signal, so that the desktop of annoying cables and wires to strip. Even if your computer does not have a built-in Bluetooth receiver, you can create a Bluetooth dongle, the function adds the system to connect. If the dongle is not working to resolve the situation.
1. Check the system requirements for the Bluetooth dongle. If the system does not fit all the requirements, the device will not work. The requirements for the Bluetooth dongle can be printed in the manual and packaging. You can compare that with what is running on your computer by clicking "Start" "Control Panel" and "System". This gives the computer hardware.
2. Unplug the Bluetooth dongle, restart the computer, plug it into a USB port. If you leave power on the computer with the dongle already instead, the system can not detect the devices. Restart the computer and perform this action helps to correct the problem.
3. Remove the dongle from the USB port and plug it into another compound. Some USB ports do not meet certain computer hardware detection. Changing the connection port fixes this.
4. Install the driver on the included CD driver installation. Without the driver, the computer can not detect and use the dongle. Insert the installation CD driver on your computer and follow the steps on screen to install the driver on the system.
Computers & Internet Logo
My jbl charge 2 power light stays on but wont turn on or off. What's wrong
if its connected via the included usb cable to your device , it will as power is being transferred via cable to units battery, if your using Bluetooth only , device will stay on as long as any Bluetooth signal is in range , and this can be any devices Bluetooth signal , even your thermostat will trigger this to stay on , use your phone to scan for other sources of Bluetooth ? it should develop a list of avail blutooth devices in range (they might not belong to you??)
Jun 25, 2015 | JBL Audio Players & Recorders
i have internet connection but cannot access internet
Bluetooth connections allow devices to connect without the use of wires or cables.
Some users of the Sony Vaio laptop computer have encountered problems with the connection of Bluetooth devices with their computer.
The problem lies with turning on the Vaio's Bluetooth function.
This is turned on through the computer's Wireless Switch Settings manager.
The icon for this is in the system tray in the taskbar when the computer is first purchased.
Double-click the "Wireless Switch Settings" icon in the system tray of the taskbar.
It is a a blue-green icon with "LAN" in one corner and "B" in the other.
Check the "Enable Bluetooth Device" setting in the Bluetooth Device section.
Click "OK."
If the device was already enabled, change the wireless LAN from "2.4GHz" to "5GHz" because, as the warning message should say, using the 2.4GHz wireless LAN and the Bluetooth device can make the connection unstable.
Click the "Apply" button after the appropriate boxes are checked to activate the Bluetooth signal. A blue light should come on near the computer's on/off switch for the Wi-Fi radio.
Click "OK." Another dialog box should appear explaining that the Wireless Switch Settings icon should now be in the taskbar.
Use this icon if you need to turn off or on the Bluetooth device in the future.
http://supportforsony.iyogi.com/vaio-f-series/bluetooth-4.html
sony support
Apr 15, 2014 | Sony Vaio Tap 20
how to turn on bluetooth radio
Which operating system ???...
There are a variety of ways to connect to the Internet or a home/business network using your Hewlett-Packard (HP) desktop computer---via a modem, Ethernet cable and even wirelessly.
A wireless connection works by sending a signal from your modem or router to your HP desktop's built-in wireless radio.
The radio receives and processes the signal so you can access the Internet or a home or business network.
In order for the signal to be received by your HP desktop, you must enable the wireless radio within the computer's configuration.
Click "Start," "Control Panel."
Double-click on the "HP Wireless Assistant" icon.
The HP Wireless Assistant dialog box will open.
Click the "Turn On" button next to the words "Wireless LAN."
Click "Close" to activate the wireless radio.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00045315&product=12455 - DeviceEnabled
Using Bluetooth Devices (Windows XP)
http://h20239.www2.hp.com/techcenter/wireless/wireless_TS.htm
Wireless networking center
Aug 30, 2013 | Packard Bell Computers & Internet
I have a dell dimension 4600 which is having intermitent problems connecting to the internet via a hardwire connection to a verizon fios wireless router. The router works fine with my dell laptop both when wired and wireless. Updated network driver on the dimension 4600, checked cables, reset TCP/IP and DHCP settings, even rolled back system restore to before problem existed - I am at a loss for what to try next. Any ideas other than getting a new computer or reverting back to my cablevision IP service and modem?
I assumed you adapted the pc with a device for wireless connection ..if all the other are OK ..the problem is this device ......try it on other computer ..if it works ..its just a compatibility issue ..if not its a problem with it ...
also try to change the freqvency they work in ..if it possible ....or change the position ..cause they work on a radio wave and you might interfere with something when it goes out of signal ...
Jun 16, 2009 | Dell Dimension 4600 PC Desktop
789 people viewed this tip
David Payne
David Payne
