Tip & How-To about Computers & Internet
How can I disable Bluetooth on a Toshiba Toughbook?
Bluetooth is a piece of hardware installed on your PC and controlled by software and a driver. There are several ways you can disable the Bluetooth software on a Toshiba Toughbook. There are several programs you can use a piece of Bluetooth hardware in case you have problems with the current configuration to control.
1. Open the Start menu, choose "All Programs" then "Startup". Right-click the Bluetooth Manager and remove it.
2. Restart the computer. If Bluetooth is still going automatically to the next step.
3. Right-click the Bluetooth icon in the taskbar. Select "Options", "IT Admin" "IT Security", "Settings" and "Bluetooth Limit" settings.
4. Select "Enable Bluetooth when you leave the Bluetooth Manager" and "Do not register with Bluetooth Manager startup."
Computers & Internet Logo
Bluetooth not working. Disabled? Or?
Bluetooth uses a number of drivers working together called the Bluetooth Stack. These need to be loaded in a specific order on boot up. Best way to fix is to remove the drivers and then using the hardware/device control remove the Bluetooth device, then reboot the machine and the O/S re find the device and load the drivers in the correct order. If any driver is missing it will be listed at this stage so have pencil handy.
Mar 19, 2015 | Computers & Internet
how do i turn on my bluetooth on my emachines pc
Click the "Start" button, then choose "Control Panel," "Network and Internet" then finally "Setup a Bluetooth enabled device."
Power on the Bluetooth Hardware you want to connect to the computer. You must have some sort of hardware to connect to the computer, in order to enable the Bluetooth connection.
Click "Add" and the computer searches for any Bluetooth hardware in the area. Once it detects the hardware, select it and click "Next."
Type in the passkey for the Bluetooth hardware (found in the device's user manual) and click "Next."
Install any drivers now that came with the Bluetooth hardware. (Insert the driver installation CD that comes with the Bluetooth hardware, wait for the the installation wizard to load onto the screen, accept the license agreement, then click "Next" for the installation name and location and select "Install" to install the drivers.)
Choose "Locate and install driver software" if there are provided drivers. If not, click "Don't show this message again for this device" and click "OK."
hope this helps
Aug 12, 2012 | E-Machines eMachines W2686 PC Desktop
how to download a bluetooth on my laptop?
Yourcomputer ether has bluetooth or not. If your computer has bluetooth and it isnot working, you probably need drivers. You can find them by google "thename of your computer + bluetooth driver".
If your computer does not have bluetooth you can buy cheap bluetooth adapter.
Bluetooth 2.0 Adapter Dongle (Amazon)
May 08, 2011 | Computers & Internet
how can i connect my nokia n70 mobile to desktop via bluetooth.plz tell me what to install the software for that.write now im with windows xp2.plz help me.i doesn't have any software regarding bluetooth.plz tell me were can i find the bluetooth software for desktop and how to install it. plz explain in step by step manner plzzzz
Dear Goutam,
Welcome to Fixya Support.
Generally every bluetooth device comes with driver CD.Some bluetooth drivers may preinstalled or inbuilt in windows XP with plug and play support.If bluetooth device drivers not present in windows, you have to install driver manually from CD, supplied along with your bluetooth device.
After Inserting bluetooth it pop up a message"New Hardware found",if drivers are inbuilt, operating system directly installs driver for your bluetooth device.
After Installation Go to control panel of your PC click on bluetooth icon,then click on search for active devices, if your mobile bluetooth is on pc will show your mobile name,then you have to pair your pc and mobile by supplying same pass key on both devices. So it completes pairing. Now you can share files between PC and mobile.
After installing bluetooth driver you can install Nokia PC Suit software for better management of your mobile content.
I think it solves your problem
If you have any difficulty leave a comment,we were happy to assist you.
Have a Nice Day!
Mar 27, 2010 | Computers & Internet
hp mini 1000 cannot receive files using bluetooth from mobile phones
When a notebook is configured to automatically download and installupdates from Microsoft´s Windows Update, the Bluetooth hardware may notfunction after certain updates. The Windows Update function may installMicrosoft versions of the Bluetooth software and drivers that areincompatible with HP products.
Method 1: Re-install HP Bluetooth software Do the following steps to uninstall the Microsoft software and re-install the Bluetooth by HP software.
  1. Click Start, Control Panel, then Add or Remove Programs.
  2. From the list, Click Remove next to the Microsoft Bluetooth Drivers.
  3. Once the drivers have been removed, click Start, Help and Support then Update Software & Drivers.
  4. When prompted, click System Health Check. When presented with a listing of Updates for Driver, Bios and Software, select HP Bluetooth software.
  5. Follow the prompts to install the software.
Method 2: Review Windows updates before installation Do the following steps to prevent Windows from automatically installing incompatible Bluetooth drivers in the future.
  1. Open the Windows Update site and under the Automatic Update section click Pick a time to install updates.
  2. On the Automatic Updates window, click More Options.
  3. Select the Download updates for me, but let me choose when to install them option and click OK to accept the change.
  4. In the future, when presented with a list of updates, do not install any Windows Bluetooth updates.
Jan 04, 2009 | HP Mini 1000 Netbook
1,190 people viewed this tip
David Payne
David Payne
