Tip & How-To about Computers & Internet
How do I restart a Bluetooth Stack?
Bluetooth is a wireless technology used primarily to connect a serial cable to be replaced by automatically connecting two associated equipment which are close to each other. Microsoft Windows 7 operating system includes support for Bluetooth devices using drivers typically supplied by the Bluetooth device. When a Bluetooth device that is configured to associate a computer with Windows 7 is disconnected from the computer, restart the Bluetooth stack to solve the problem quickly in many cases.
1. Click the "Start", click "Control Panel" and double-click Administrative Tools.
2. Double-click "Services" item in the list. The "Services" window will appear.
3. Click here to see the "Bluetooth Support Service" to highlight it and click the "Restart" on the left side list of services.
Computers & Internet Logo
how do wireless headphones work
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
Feb 15, 2014 | Sony Audio Players & Recorders
what is blu tooth
Hi
The short description: Bluetooth technology is a global short-range wireless standard that allows a broad range of electronic devices to connect and communicate with each other. Bluetooth technology is essentially a cable-replacement technology. From mobile phones and headsets to MP3 players, PCs and peripherals, Bluetooth technology allows these devices to connect.
Read Mode...
May 29, 2011 | Computers & Internet
most of the time my Belkin mouse will work great, today it won't do anything, i do not think it is the batteries. what do you think the problem can be?
Your wireless mouse is likely using Bluetooth in the 2.4 GHz industrial band which is shared with other wireless technologies such as cordless phones and 2.4 GHz WiFi. The Bluetooth protocol was designed to minimize likelihood of it interfering with anything else in the band in that it will refrain or back-off from transmitting in the presence of other signals. Unfortunately, this means that often, bluetooth is at the lowest priority and devices using it will be slowed down or stop working in the presence of interference. Its signal also tends be the lower than the others as it was intended to connect nearby peripheral equipment such as a mouse, printer or scanner to a computer. WiFi and cordless phone signals are much stronger as their coverage is typically for a whole house. The congestion on the 2.4 GHz band is being relieved somewhat with the use of the 5 GHz band for newer wireless technology and you may want to take advantage of this by replacing existing 2.4 GHz equipment with newer cordless telephones and WiFi with 5 GHz capability. In the interim, if your problem is on a computer that is close to your wireless router, you may find some relief by using a direct ethernet connection using UTP cable with RJ-45 jacks on each end to go from the computer's 10/100 LAN port to one of the four LAN ports on your router. Also, if you have a 2.4 GHz cordless phone in close proximity, you may want to relocate your cordless phones away from your computer. Click on the following link for more information on Bluetooth....
http://en.wikipedia.org/wiki/Bluetooth
Feb 19, 2011 | Acer Computers & Internet
Is Acer Aspire 4720z equipped with a built in blue tooth device
The quickest and easiest way i have found is to press the Fn button + the one that turns on your wireless networking if you have one.
But i looked up your system and it says it comes with blue tooth.
"Communications Intel® Wireless WiFi Link 4965AGN network connection supporting 802.11a/b/g/Draft N wireless LAN, Acer® SignalUp technology for enhanced antenna efficiency
or
Intel® PRO/Wireless 3945ABG network connection supporting 802.11a/b/g wireless LAN, WI-FI CERTIFIED™, Acer® SignalUp technology for enhanced antenna efficiency
Bluetooth® 2.0 + EDR (enhanced data rate) wireless PAN (select models only)
Gigabit LAN, Wake-on-LAN ready
V.92 56Kbps* data/fax modem, PTT (postal, telegraph, telephone) certified in select countries, Wake-on-Ring ready
Acer® Video Conference with integrated Acer® Crystal Eye webcam supporting Acer® PrimaLite technology, which consists of a premium sensor, firmware and lenses to provide superior video performance under low-light conditions (select models only) "
I found this here
Feb 27, 2009 | Acer Aspire 4720 Notebook
247 people viewed this tip
David Payne
David Payne
