Tip & How-To about HP 1020 Plain Paper Thermal transfer Fax
Try hard reset to clear most software lockups.
Step 1: unplug cord step 2: plug unit in. Press and hold asterisk (*) key while dots scroll across display step 3: release (*) key when "all memory init" message appears step 4: unplug again step 5: plug unit in. Use L/R arrows to select country. Enter. Select language. Enter. step 6: Use Menu to set # of rings; volume.  Record message; Select TAM/FAX
HP 1020 Plain Paper Thermal transfer Fax Logo
tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
Error:oxc18a0401??
Hi There,
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Nov 04, 2010 | HP Photosmart 3210 Printer
How do I fix Error:Oxc18s0301 Ink system failed.
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
Full reset
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Aug 20, 2010 | HP Photosmart C6280 Printer
error: Oxc18a0401
here.. check this out. a solution to your problem.
Semi reset
Full reset
Aug 16, 2010 | HP Photosmart 3210 All-In-One InkJet...
0xc18a0001
Semi reset
Full reset
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
Jun 02, 2010 | HP Photosmart 3210 Printer
1,644 people viewed this tip
Seeker5211
Seeker5211
