Tip & How-To about Computers & Internet
Nail Polish and Cable Connecters!
After spending 24 years in the military and moving every year or two, I got tired of looking for my stereo manuals to find out where to hook all the cables. Then one day, I noticed my wife and daughter had accumulated an awesome supply of nail polish and the idea light went off in my head.
I got several different colors of nail polish together; went to the back of the electronic cabinet and put a dab of polish above the connectors (both ends) and the same color on the cables (both ends). When I ran out of different colors I just started doing a double dab on both sides.
The next time I had to move, I had absolutely no trouble hooking everything up and getting operational!
Now when I pass a cosmetics counter, I ask the clerk if they have any samples that I could have. This trick works on most anything, even when I disconnect electrical cables on my vehicles, I mark each side with nail polish and never have to wonder if I got it connected to the right place.
Computers & Internet Logo
I need to change the atomic clock from military time to standard 12-hour format...can't find original manual...have owned the Radio Shack clock for 5 years.
Hit the set button until the number 24 shows up instead of the time. Hit the "+" button once, and it will switch from 24-hour to 12-hour display. Hit the set button to cycle through the rest of the settings.
Jun 22, 2010 | SkyScan 86709 Atomic Wall Clock
my kia 2004 optima has a stereo amp that causes a battery drain, any suggestions on how to repair an amp w/o having to replace it? I did electronics 28 years ago in the military so I know the basics at least. ph 918-437-8156
If it is an after market, it was probably hooked up direct. the power/on should be hooked to the radio. if it is then you have a short. only other solution is to hook a relay to the main power feed and have it come on with the igntion. be carefull cutting/splicing wires as not to cut into a computer wire and possibly blow a computer
Jun 14, 2010 | 2004 Kia Optima
how do i change from military time on a insta-set alarm model 40009?
This may or may not work. The 40009 and 40010 are almost identical. The 40009 doesn't mention military time and the 40010 does, so you might want to what the manual says. 40010 manual and 40009 manual. According the 40010 manual, is says:
Displaying the12/24 hour, Date, Month and Year:
Display the 12/24 hour by hold the "+" button for 2 seconds. To display the date, month and year by press the "-" button, the year appears and then if pressed again, the month and date (eg. “12 31” means Dec 31) appears.
So maybe that will do. I have a 40010, but my manual is different from the one on the website. Its DST button and not Alarm Set button to change the time. So maybe try holding down different buttons for a couple of second see if one lets you change it between 12 and 24 hour. Good luck, hope this helps.
Mar 16, 2009 | Equity Time USA Insta-Set 44200 Clock...
Getting the clock off military time
This is controlled by hardwired switch (12/24) OR digitally during menu setup sequence.
Sep 17, 2017 | Audio Players & Recorders
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Nov 28, 2007 | Bose Wave Radio
284 people viewed this tip
David Payne
David Payne
