Tip & How-To about Computers & Internet
How to get your battery on your laptop to hold battery longer.
Haven't you tried then your battery is completely dead and theres nothing to do than buying a new battery.
Why dont be careful not to ruining your new battery.
An laptop battery dont have good of getting charge all the time, so if you want your laptop to have the charger in all the time you should take the battery out off your laptop and then turn if on with the charger in.
When you wont charge your battery unnecessary.
Computers & Internet Logo
94 chevy k1500 no power to anything replaced battery cables so there is power to the starter but that is it no lights of any kind at all and nothing on the dash just dead.
One thing to check would be the ground cable from the battery, make sure it is still connected to the battery and the other end is connected to its ground bolt. If it all looks connected it could be cracked somewhere so try using a new wire.
Jul 31, 2017 | Chevrolet Cars & Trucks
what are the possible reasons my 97 geo metro won't turn over after running the battery dead, then replacing it with a brand new battery ?
blown fuse.
bad wiring
forgot to charge new battery up to 12.6vdc reseted.
the head lamps work , keys in pocket (by law) and
are #1 first thing to trouble shoot when dead (easiest)
so, got 12v at all under hood fuses? ????????
id bet not. and any $10 voltmeter can find this easy.
buy one. use it. and save a bundle....
Aug 24, 2014 | 1997 Geo Metro
Just replaced battery.old one went dead overnight but I had never checked voltage, Now, after installing new battery, voltage remains at 14.9 to 15 volts. Will this fry my batt? Is voltage regulater the problem and are they replaceable or will I have to buy a complete alt?
14.9 to 15 volts is normal for a battery and the voltage regulator is built into the alt they dont often make a rebuild kit for alts anymore so buying a new one is easyer but you dont have to do that cause there is nothing wrong with it.
Dec 13, 2010 | 2003 Pontiac Bonneville
turn key to start and nothing
Not if you left your headlights on all night and completely drained the battery. if it is dead, try to jump it, if you get some sort of power with the jumpers attached, go buy a new battery.
May 29, 2009 | 2001 Toyota Tacoma
196 people viewed this tip
David Payne
David Payne
