Tip & How-To about Computers & Internet
How to Turn Off Safe Mode on Windows Vista
The Safe Mode is used to detect the technical and software problems in windows Vista. This is an effecting way to diagnosing the problem, that's why most of the technicians prefer this way to resolve the problem. But Safe Mode disables the most of the advance functionality of your computer. So use the Safe Mode only for diagnosing the problem and as you diagnose and repair the problem get back your windows to normal mode.
For reverting back to normal mode at windows Vista, an option occurred which has to be select within limited time and if you select the Normal Mode option within this limited time, your windows will revert back successfully but if you waste the time, you have to restart your computer again for getting this option. You can select the Normal Mode option through arrow keys or by pressing the number at which the Normal Mode will appear.
Sometime your computer does not display the Mode Selection Menu. This is not a problem you can get this menu and revert back your windows Vista into Normal Mode through the following instructions.
Instructions
If you want to revert your Windows Vista into Normal Mode from the Safe mode but your system is not giving you option to select the mode, follow the given instructions:
Restart Your Computer: To restart the computer you need to take the following step:
- Click on "Start" button at the left side of Task Bar. In Safe Mode of windows Vista the Start button appears at the same place where it appears in the Normal mode. Select "Turn Off Computer" from the Start Menu. Then, Select 'Restart" from the pop-up menu.
When your computer has been shut down place your finger at F8 key. As your computer starts to boot computer devices for restarting your computer, press F8 key again and again unless a menu appears on the screen. This menu is Mode Selection Menu.
Note: If your computer won't give you Mode Selection Menu at the screen that's means you have lost the time of getting option. In this condition restart your computer again and again, and then press F8.
When you get Mode Selection Menu on your computer screen, stop pressing F8 key. Now choose the Normal Mode from the list by the following method:
- You can select the Normal Mode by pressing the number on which Normal Mode appears in the list.
- You can select the Normal Mode manually through the Arrow Keys. Press the down key to reach at the Normal Mode option in the list and press Enter.
Then wait for a while to reboot your Windows Vista in Normal Mode.
This is the method of changing Mode in windows Vista. You can follow these instructions at any time to revert your windows Mode.
Computers & Internet Logo
LOST THE PASSWORD FOR VISTA
  • If you have password reset disk then you can easily reset the password..
  • Reset Windows Vista Password in Safe Mode:In Windows Vista there is a hidden account called Administrator which does not show up on the login screen but it is always available for use if required. If you didn't change this Administrator's password, the password is empty by default. You can boot up in Safe Mode (by pressing F8 when your computer starts) and log on with the built-in Administrator account. After getting into Windows, you can reset any Vista account password easily!
  • Use the Sticky Keys Trick to Reset Windows Vista Password: The Sticky Keys trick to restore a forgotten administrator password is reliable, easy to carry out, and does not require third-party software. All you have to do is boot up from a Windows Vista setup DVD, launch the Windows Recovery Environment (RE), and then replace the sethc.exe file with cmd.exe. but you have to use a Vista DVD.
  • Reset Windows Vista Password by Third-party Software
You can ask experts for any technical help at-http://www.vtechsquad.com
Sep 05, 2012 | Acer Aspire Timeline AS3810T-8503...
dell inspiron mini 10 Turn it on, put in password. screen says windows did not start up sucessfully. A recent hardware or software change may have caused this. then i go to the last known good configuration- start windows normally. theres also option for- safe mode- safe mode with networking- safe mode with comand prompt. all of these options take u to a page that says; a problem has been detected and windows has been shut down to prevent damage to computer- unmountable_boot_volume. then at the bottom it says; technical infromation: ***STOP: 0xooooooed (ox86fc67b8, 0xc0000006, 0x00000000, 0x00000000) cant get it off this screen to try to do anything. tryed all buttons, ctrl+alt+delete...... help plz
A blue screen with white writing appears on my computer,
just before windows is about to begin and it reads:
A problem has been detected and windows has been shut
down to prevent damage to your computer.
UNMOUNTABLE_BOOT_VOLUME
If this is the first time you've seen this stop error
screen restart you're computer.
If this screen appears again follow these steps:
Check to make sure any new hardware or software is
properly installed. If this is a new installation, ask
your hardware/software manufacturer for any windows
updates you might need.
If problems continue, disable or remove any newly
installed hardware/software. Disable BIOS memory options
such as caching or shadowing. If you need to use safe
mode to remove or disable components, restart your
computer, press F8 to select advanced startup options,
and then select safe mode.
Technical information:
STOP: 0XOOOOOOED
(OX8OED4AF8, OXCOOOOO32, OXOOOOOOOO,OXOOOOOOOO)
I cannot go into windows even in safe mode, and I don't
know how to execute any of the other things it's telling
me to do.
It may have something to do with my virtual memory as
windows had to increase it while I was playing a computer
game, or because I added some extra pictures I downloaded
to a computer game folder where the default pictures were
already stored.
if u cant do these then reinstall the operating system.
Sep 03, 2011 | Dell Inspiron Mini 10 Notebook
forgot code and hint answer how do i reset without these
Step 1: Enter Safe Mode
a) Start or re-start your computer.
b) Before the Windows 7 loading screen appears, Press 'F8? to enter Advanced Boot Options.
c) Use arrows to choose 'Safe Mode' when you can see the Advanced Boot Options screen.
d) Press 'Enter' and wait for Windows 7 files to load.
e) Log on with an administrator account when you can see the log on screen
Note: Well, when you are presented with the Advanced Boot Options screen, there are 3 types of Safe Mode. They are the Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt, and the 3 options are all available for you. Here above we take Safe Mode as an example, but if you choose Safe Mode with Command Prompt, you'll need to input related to command prompt to reset the password.
Step 2: Reset the forgotten Windows login password in Windows 7
Now you could diagnose and solve some serious computer problems in the safe mode and reset the forgotten Windows login password in Windows 7 as follows:
1. Click 'Start' button, input 'lusrmgr.msc' into the Search box and press 'Enter'.
2. In the 'Local Users and Groups screen', click 'Users'.
3. Right-click the account that you need to reset the password for, and then click 'Set Password'.
4. Type and confirm the new password, click 'OK'. (You can go to 'Local Users and Groups' screen by right-clicking 'Computer' to select 'Manage' on desktop.)
Step 3: Log on your password protected PC again with the new password since you have successfully performed Windows password reset for Windows 7.
Jul 18, 2011 | Microsoft Video Game Consoles & Games
382 people viewed this tip
David Payne
David Payne
