Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Aunsoft VRO to AVI Converter - Convert VRO Videos to AVI
Best Way to Deinterlace VRO Videos - Convert VRO to AVI
.VRO files are created by DVD video recorders or camcorders with Mini-DVD disc using the DVD-VR format. The disc has a 'VR_MOVIE.VRO' file, containing the raw audio and video data for all video recordings. The recording metadata along with navigation data are stored in the 'VR_MANGR.IFO' file. A backup copy of this file (VR_MANGR.BUP) is presented as well. VRO Codecs: MPEG2, same as VOB but uncompressed raw video and audio. So in some cases you can treat the VRO files just like .VOB files, but in many cases you can not use, play or edit VRO file easily.
Audio Video Interleave (AVI) is a means of digitally storing audio and video media content in a file for playback. AVI-formatted files employ the file extension .avi. The header portion of the AVI-formatted file provides details about the file contents, such as width, height, and frame rate, while the chunks of information store the actual audio and video data. A key advantage of AVI format is its ability to be played on the majority of computers worldwide.
With Aunsoft Best VRO File Converter, we can convert VRO file to AVI with best quality, fastest converting speed, excellent A/V sync and so on. And we also can use the VRO File Converter to convert VRO file to friendly video formats just like mpg, wmv, mkv, mp4, mov, mpeg, dv, etc for playing on iPad, iPod, iPhone 4, iTunes, QuickTime, PSP, Apple TV, Android Phones, etc so that we can watch our favorite VRO conversion file everywhere.
Follow the step to convert VRO files to AVI now.
Step 1: Free download, install and launch best VRO to AVI Converter.
Step 2: Click "Add" to browse the documents for the VRO videos you want to convert from DVD Recorder or Mini-DVD Disc. You can add more than one file at a time.
Step 3: In the drop down list menu of "Format", please select the output video format you want to get. You want to convert VRO videos to AVI, just select AVI. Then specify a location on your computer where the new file should be saved.
Tip: If you want to trim or crop your VRO files and get the wanted part or area, if you want to replace original audio and add background music to the VRO videos, if you want to deinterlace, remove interlaces or image noises of the videos, please click "Edit" to get into editor windows and start your DIY process.
Step 5: Click "Convert" to begin converting the VRO to AVI files. Quickly you could get your converted files with high quality.
Now wish you have already known how to convert VRO files from DVD Recorders or Mini-DVD Discs to AVI. Don't hesitate, download and convert VRO to AVI now.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
I have a magnavox ZV427MG9A DVD/VHS recorder. Recently I deleted all the titles/programs that I no longer needed so that I could reuse the disc for recording. I was able to record two programs fine, but when I went to record on the next program, the recording stopped after about 8 minutes. The disc showed that there was 4 hours of recording time left, and I did record on the correct speed to allow this, but the recording time would not go past approx. 8 minutes. And after that time, a message appeared saying "recording error: cannot record on this disc". Why this didn't appear before I went through the recording setup is strange--would have saved me alot of time and frustration. Any idea why I couldn't record past the first program, even though there was sufficient recording time, according to the disc?
Sorry to bother you sirs, but it seems that you know much about DVD Camcord playback problem. I have a question about my camcord video output format may i ask. I have a vro file that can'tbe recognized by my VLC player, so I use this VRO mp4 converter([url]http://www.videoconverterfactory.com/tips/vro-converter.html[/url] to convert the vro file to mp4. After that conversion process the .VRO file can be played again, but I do not know why the output has no audio output, no sound. Do you ever met such a kind of problem? VLC can play .VOB very well because I have checked. It should be similar to .VOB, but why VRO cannot be recognized by VLC Media Player, it doesn't make any sense. Is there any free and simple method to directly run .VRO file on my PC without using any third-party video conver
have magnavox ZV427MG9A DVD VHS recorder Recently deleted all the titles...
Mar 15, 2017 | Magnavox ZV427MG9 DVD Recorder VCR
Editing videos taken from canon dc100 camcorder
I see here that . . .
"The DC100 takes 3-inch Mini DVD-R/RW discs, and like most of its competitors, can fit about 20 minutes of best-quality video on one. If you choose to initialize a disc for playing in a standalone player, the camcorder writes standard VOB files; if you initialize for future editability, it records in the VRO format. Windows Media Player can play the latter if you rename the file with an MPG extension, however the aspect-ratio information gets lost--that info is encoded into a separate file--so 16:9 video will get squashed into 4:3. "
Cnet Reviews.
Your videos are recorded in the common DVD format called MP2.
They have the extention .MPG so if you copy the video files to your computer, and change the end of the filename from VOB, or VRO to an MPG then your software can recognize it as the MP2 format that it is.
There is a Windows XP program, called Windows Movie Maker, it can open your video files and provide you with most of the video editing tools.
Cheers.
Jun 14, 2009 | Canon DC100 DVD Camcorder
Archiving Digital Camcorder Video - Ideal Formats
Let's try to bottomline this. If you want said DVD to play in most players, you'll be encoding the video according to standards. The current DVD is MPEG2. At the current time, most people just have DV camcorders so you don't see the generational loss as you move the video from DV to DVD. At least I don't.
Sep 13, 2005 | Sony DCR-HC15 Mini DV Digital Camcorder
1,399 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
