Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Watch/Enjoy Joined Panasonic HS900 MTS Video on Asus O!Play in Full HD 1080p Resolution
Enjoy Full HD Video on O!Play-Combine HS900 MTS into one file without conversion for playing on Asus O!Play
These days many of us have a constantly growing media library, with our favorite music, movies, and photos in a variety of formats and locations. The ASUS O!Play is designed to easily bring your media into your living room, without sacrificing quality. Enjoy video in full HD 1080p resolution,full-fidelity audio, and photo slideshows on your HDTV or home theater setup. With impressively wide format support, a wealth of connection options, and playback over a network or directly from USB and eSATA drives, the O!Play is an elegant and modern media solution. Such a cool HD media player supports formats include full hd 1080p mts.
If you are interested in recording with HD camcorder, like Panasonic HDC-HS900 which give MTS extension, you can directly Transfer and Enjoy Panasonic MTS files to Asus O!Play via HDMI. However, before enjoy them with O!Play, you may want to do simply editing like cutting off unwanted or unimportant parts and then merge or join the trimmed MTS files into 1 file while keeping the same format, without losing any quality. Sometimes you can also put them in a format for devices to watch anywhere in the house or on the go.
Now I will show you a fast way to Cut off Panasonic HS900 MTS clips, and then Combine HS900 MTS into one file without conversion for playing on Asus O!Play with Full HD 1080p resolution.
Step 1. Capture MTS from Panasonic HDC-HS900 AVCHD camcorder to Aunsoft Final Mate for Mac.
Free Download and Run Aunsoft Final Mate for Mac as the fast MTS Cutter/Joiner without Conversion, and use USB cable to connect your Camcorder to PC. Then follow the camcorder wizard to import videos. After selecting the Import option, you will face the window like below to choose the video clips for importing to Aunsoft Final Mate for Mac. The videos would be listed on the "Camcorder" tab.
Step 2: Create a Movie for Cutting and Joining Panasonic HDC-HS900 MTS clips.
Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split/join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created.
Step 3. Split or cut off unwanted parts from HS900 MTS movie for Asus O!Play.
From the timeline, you may notice the vernier, which is used as time pointer. Click on the Vernier, and move to the timeline you want to cut, and click the Split button to cut the video. Then select the unwanted or unimportant parts and click Delete.
To change video sequences, just click on the video clip on timeline, drag and drop to the left or right for the position as you like. One movie will be exported as one file with Aunsoft Final Mate for Mac.
Step 4. Merge/Join/Combine HS900 MTS without Conversion for Asus O!Play.
Click the Export button and choose lossless output, the HS900 MTS cutter/merger for Asus O!Play will start joining large .mts files into one mts file without conversion at the fast speed. The non-conversion process will prevent loss of quality when joining MTS files for Asus O!Play with 1080p.
After a few seconds, then connect the lossless output mts format with Asus O!Play via USB. By Connecting the O!Play HD Media Player via HDMI with HDTV , you can Enjoy full 1080p high-definition video and digital audio output for lossless audio transfer to your receiver or TV.
Tips:
If you think that MTS file is so large that can't play smoothly on O!Play, you can also use this program to convert MTS file to MP4, AVI, MOV, WMV, etc with smaller size for Asus O!Play.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
how do I save AVCHD movies as MPEG files? My software converts them to .cont or .iis or .m2ts or .tmb I have a panasonic dmc-ft1
Wondershare Video Converter Platinum is the best HD video converter and AVCHD video converter which can convert HD video and AVCHD video to avi, convert m2ts to avi, convert mts to avi, convert ts to mpeg etc.. with excellent quality.
Sep 22, 2009 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
How to Play AVCHD with Sony DSC-HX5V on VLC Media Player? After recording some HD videos with the new Sony Cyber-shot DSC-HX5V, do you want to play the videos on computer? You may face the problem that the full HD videos at 60 fps in .mts file format do not play properly, and the playback on VLC is choppy. If the VLC media play shows the HX5V .mts video, but with pixelation or interlaces, you can adjust VLC to see if the video playback on VLC is perfect without interlacing artifacts. Just play the video as normal videos on Mac, and right click on the player to choose Video > Deinterlace and choose the options like Discard, Blen, Mean, Bob, Linear, X, Yadif, Yadif (2x). If the above solution does not work for you, you may try Mac Sony DSC-HX5V MTS converter to deinterlace AVCHD, convert HD .mts to HD .mov, HD .mpg for VLC media player. The output HD MOV is compatible to QuickTime too. Here are the simple steps to convert Sony Cybershot DSC-HX5 .mts to HD .mov with Aunsoft MTS/M2TS Converter for Mac. Step 1. Load Sony DSC-HX5V videos to Aunsoft MTS/M2TS Converter for Mac. Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony DSC-HX5V MTS converter, and click the Add button to load .mts videos. Step 2. Choose HD .mov output. Click the Format option and choose HD Video > H.264 AC3 HD Video(*.mov) for converting .mts to .mov. Tips: The Mac Sony DSC-HX5V MTS converter will convert 1080i AVCHD to 1920x1080 by default. If you records videos at 1440x1080, you can click the Settings button and change video resolution by choosing 1440x1080 from the drop down menu. Step 3. Convert Sony DSC-HX5V .mts to HD .mov. Click the convert button under the preview window, and the conversion from Sony DSC-HX5V .mts to QuickTime HD .mov starts immediately. When the conversion is finished, you can play 1080p videos on VLC without interlaces or choppy problem on Mac. Your QuickTime will play the HD .mov videos seamlessly too. The Mac Sony DSC-HX5V MTS converter would work perfectly on Mac Leopard, Snow Leopard for your iMac, MacBook Pro.
Jul 15, 2010 | Computers & Internet
1,498 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
