Tip & How-To about Dell Vostro 220 Desktop Computer
Dell vostros 220 cd/dvd drive not working
My cd/dvd drive quit working device manager showed the triangle and ! mark, properties showed code 10. shut power off, took side case off, unpluged both cd/dvd's, from the board, restarted machine let it reboot, shut power off again,plugged both cd/dvd's back in, restarted machine, both were reinstalled and now working. hopes this is some help to somebody else. thanks jim.
Dell Vostro 220 Desktop Computer   Logo
optiarc dvd rw driver shows code 19 error .i have tryed to reinstall ,but no use.
The below step will surely resolve the issue..
CD/DVD drive in device manager and the CD/DVD properties in device manager shows error code 10 , 19 , 31 , 32 , 39 or 41, please use the following steps:
This issue occurs due to an incorrect registry entry, which might be created due to installation of an incompatible CD/DVD burning program. We will remove the registry entry and re-install the CD/DVD drive and the issue will be fixed.
1. Click on Start and type regedit in the search box and hit enter. It will open Registry Editor window.
2. It will open registry editor.
3. Click on File and Export, it will open a new window.
4. Select Desktop from left pane in the new window and put file name as regbackup and click on Save.
5. It will create a back up of the registry on desktop.
In case something goes wrong during modifying registry, this registry backup can be used to restore to original registry.
6. Now in registry editor click on triangle symbol next to the following items in the left pane:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
7. Locate 4D36E965-E325-11CE-BFC1-08002BE10318 below class and click on it. Make sure you have selected the correct entry as all the entries looks almost similar.
8. Look at right pane and check if you see UpperFilter and LowerFilters entries.
9. Please right click on UpperFilter and LowerFilters and select delete.
10. make sure there are no other UpperFilter and LowerFilters entry in that window.
11. Close registry editor.
12. Now please click on Start and type device manager in the search box and hit enter.
13. It will open Device manager window.
14. Click on + sign near CD/DVD entry and it will show the name of the CD/DVD drive with a yellow mark near it.
15. Right click on it and select uninstall.
16. It will remove the CD/DVD entry from device manager.
17. In Device manager, click on Action > Scan for hardware changes to re-install CD/DVD drive.
18. Now you should see the CD/DVD drive entry.
19. Do you see any yellow mark near it now?
20. Please click on Start > Computer and check if CD/DVD drive is listed.
21. Please insert a CD or DVD and check if the computer reads it.
May 08, 2010 | Computers & Internet
I hav VGN CR24G/BNow the problem is that it show no dvd drive on MyComputer but shows yellow triangle on Device Manager pioneer DVD-RW DVR-K17 ATA device and shows error code 39 in the device status. please assist me in fixing the problem. Thanks
Try right clicking on the triangle and choose to update driver if you have the internet choose use internet this one time option, and see if it can find an updated driver.
Unplug pc from the mains and take the side panel of, check the cables are in correctly, also check the drive is set to the right jumper setting usually master.
Also check in the bios to see if you have raid capabilities, it would be worth disabling it. It is for hard drives not for removable devices.
Jan 24, 2010 | Pioneer DVR-107D DVD±RW Burner
CD/DVD no longer working
Go to device manager and see if the device has a yellow triangle with question mark next to the name of the device. If it does, then right click on it, go to properties and see if there is any type of error code. If there is an error code, then search for that code on microsoft's website.
Feb 17, 2009 | Toshiba Satellite M55-S135 Notebook
CD rom drive not working
sounds like it's gone home early. replacement will do the trick..
Mar 06, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
3,345 people viewed this tip
mukhtar21 shaikh
mukhtar21 shaikh
