Tip & How-To about Panasonic Hair Clipper ER1511
ER151 fix to open to change batteries
Photo P1120573 push this out.
photo 1120586 Then you see two screws. Unscrew them.
You see phot 1120570
Take the plastic away.
Then you see P1120558
Then push with a screwdriver a little bit
See photo P1120568
Then take the piece away.
Photo 1120559
Take the little screw away at the end off the ER151.
This screw is visible.
Watch out for the little springs Photo 1120561.
Take out the two plastic things. photo 1120564.
Take out the elektrical PCB. photo 1120565. and cleaning it. with a little
steel wool. 1120566.
You can also contact points slightly upward. So you better contact on the PCB.
Clean the little contact's with steel wool.
Change the batteries. and put it back together :) :)) :)))
Panasonic Hair Clipper ER1511 Logo
Why won't my Epson Printer XP405 print a photo on Epson Glossy Photo paper
Your printer may need you to replace the "matt black ink" with "gloss black ink".
May 19, 2015 | Epson Office Equipment & Supplies
I have a Epson pro large format 9600, I print on canvas, I have use Photo black since I have it, but never getting a saturation ressult. I have been counsil by Epson to use Matt black rather than Phot
"Photo black" is designed specifically for glossy photo paper. Matte black is for non-glossy paper, including plain paper. Matte black will print darker on non-glossy paper than photo black does.
Oct 28, 2014 | Epson Office Equipment & Supplies
photo in bedford photo caddy
Behind the picture frame (inside the caddy) is the black backing. Put your finger on the opening on the black backing and push down gently and pull into caddy. The back will fall away and plastic frame will too.
Dec 27, 2013 | Pottery Barn Furniture
Hi there, How do I print my image on A4 without any margine. Thanks
Hi
u don;t want to use adobe phot shop, just copy your jpag file and open word and paste there and drag your photo and increases your photo size. this is tempo-rely option, Best u Install the Abobe Photo Shop.
Good Luck
May 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
how to disassemble Braun pulsonic razor,.. yes there's a screw in the 12volt inlet but there must be others else where, I assume under the rubber cover,.. but how does that come off so it may be re-installed later, damage free
To disassemble a Braun 9595 (and others like it):
Remove the rubber back and side piece by prying with a small screwdriver on one side near where the three arc design meets the silver body (photo 1). After releasing one side snap (photo 2), release the opposite side snap or use your fingers to pry around the rubber piece until both snaps are disengaged and the piece can be removed (photo 3).
This reveals the back of the shaver, which is held in place with four Torx screws. Fortunately, the screw heads are slotted so that either a torx wrench or a slotted screwdriver may be used for removal.
After the screws are removed, the shaver back plate may be lifted out (photo 4), exposing the battery and control board assembly, and the shaver/motor assembly (photo 5).
The battery is not soldered in place and may be removed by prying on one end to lift its positive or negative pin away from its contact. Then remove the battery (note that the negative side points to the shaver head. Also, the positive and negative pins are sized differently to prevent accidental reversal.
Reassembly has one essential step that must be followed or the razor will not function properly. Photo 6 shows the correct engagement of the shaver's back plate plastic pins with the shaver head's capture slots (shown "upside down"). Photo 7 shows the potential misalignment after the shaver head is inserted into the shaver body for reassembly. To overcome this when installing the shaver's back plate, ensure that the back plate's pins are first inserted into the capture slots (photo 8). Although the back plate may not appear to be positioned properly at first, it may be pushed downward which will "pull" the screw holes into alignment for inserting the screws.
Before inserting the screws, test the power ON button to ensure that all contacts have properly been made. If the shaver does not operate, check to see if any of the power tabs have been bent away from its associated contact point.justwomore_8.jpgjustwomore_7.jpgjustwomore_6.jpgjustwomore_5.jpgjustwomore_4.jpgjustwomore_3.jpgjustwomore_2.jpgjustwomore_1.jpg
Feb 07, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
2,752 people viewed this tip
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
