Tip & How-To about Computers & Internet
How to back up a offline disk folder
Backing up your computer in a folder on the hard disk that goes offline, because sometimes surprisingly simple for the Windows Sync Center. You have a network available offline. Your computer will copy the backup of the hard drive of your computer's hard drive when you're online. The folder will appear as if it were accessible online, because the files are copied to the folder on your computer and then sync when the device is online.
1. Click "Start", "computer" and open the folder with your backup folder. Right-click the backup folder and click on "always available offline."
2. Waiting for the files in the directory so that the copy on your computer available offline.
3. Right-click again on the backup folder and click on "Map Network Drive". Click "Finish".
4. Click Start, Control Panel, System and Security "and" Backup and Restore. "Click" Create Backup.
5. Select the mapped drive that you defined earlier in the Drive list. Click "Next" and follow the steps to complete your backup to adjust. Click Save Settings and perform the backup. "
Computers & Internet Logo
i forgot yhe password of my secret disk folder can anyone help me to unlock it
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Jun 17, 2012 | PrivacyRoot Secret Disk
Making a folder will not work for me??
You cannot just create new folders - the player will not recognize them.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In Device Setup - Configure Sync, write a name for your mp3 player.
3. Click Finish. The window closes and the Sync feature in the Player is displayed.
4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
5. Select the songs or entire albums from the center pane.
6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
7. Click the Start Sync button on the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In the Device Setup Wizard, select Manual.
3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
4. Select the Library option. On the left pane select Sync List.
5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
6. Select the songs from the center pane, and drag them to the Sync List.
-Tha Mp3 Doctor
Nov 13, 2008 | GPX MW3836 MP3 Player
outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
156 people viewed this tip
David Payne
David Payne
