Tip & How-To about Computers & Internet
How to back up IIS 6
Internet Information Services IIS 6, a web server application that allows you as administrator, the settings for the Exchange server organization. Part because of its importance, it is imperative that you back up the metabase of IIS 6. IIS 6 Backup helps you to recover lost data on a server crash. You must have administrative rights and permissions for this task.
1. Click the Start menu, select Administrative Tools and click Internet Information Services (IIS) Manager.
2. Right-click the name of the server or computer.
3. Move the mouse to "All Tasks". Select "Backup / Restore Configuration."
4. Click "Create Backup".
5. Enter a name for the backup to the backup configuration name. "Check the Encrypt backup using password" if you want to password protect the backup and then type the password for the backup to confirm.
6. Click "OK" to back up the IIS 6
Computers & Internet Logo
How to set up a FTP server in Windows 7
You can use MS products (FTP Service and IIS Management Console) or a third party software (FileZilla.)
To use MS, you have to enable FTP under "Add Features" in Programs and IIS service.
Then you have to configure IIS:
  1. Run Administrative Tools -> Internet Information Services (IIS) Manager
  2. Expand the local machine
  3. Right-click "Sites" and add "FTP Site"
  4. Call it "Default FTP Site" and create the path like "C:\inetpub\ftproot"
  5. click "Next"
  6. Enable Start FTP site automatically, select Allow SSL
  7. click "Next"
  8. Enable Anonymous Authentication
  9. click "Finish"
Oct 15, 2015 | Computers & Internet
Installing IIS On Windows Xp Pro
If you are running Windows XP Professional on your computer you can install Microsoft's web server, Internet Information Server 5.1 (IIS) for free from the Windows XP Pro installation CD and configure it to run on your system by following the instructions below: -
1. Place the Windows XP Professional CD-Rom into your CD-Rom Drive.
2. Open 'Add/Remove Windows Components' found in 'Add/Remove Programs' in the 'Control Panel'.
3. Place a tick in the check box for 'Internet Information Services (IIS)' leaving all the default installation settings intact.
4. Once IIS is installed on your machine you can view your home page in a web browser by typing 'http://localhost' (you can substitute 'localhost' for the name of your computer) into the address bar of your web browser. If you have not placed your web site into the default directory you should now be looking at the IIS documentation.
5. If you are not sure of the name of your computer right-click on the 'My Computer' icon on your desktop, select 'Properties' from the shortcut menu, and click on the 'Computer Name' tab.
6. Your default web directory to place your web site in is 'C:\Inetpub\wwwroot', but if you don't want to over write the IIS documentation found in this directory you can set up your own virtual directory through the 'Internet Information Services' console.
7. The 'Internet Information Services' console can be found in the 'Administration Tools' in the 'Control Panel' under 'Performance and Maintenance', if you do not have the control panel in Classic View.
8. Double-click on the 'Internet Information Services' icon.
8. Once the 'Internet Information Services' console is open you will see any IIS web services you have running on your machine including the SMTP server and FTP server, if you chose to install them with IIS.
9. To add a new virtual directory right click on 'Default Web Site' and select 'New', followed by 'Virtual Directory', from the drop down list.
7. Next you will see the 'Virtual Directory Creation Wizard' from the first screen click the 'next' button.
9. You will then be asked to type in an 'Alias' by which you will access the virtual directory from your web browser (this is the name you will type into your web browser after 'localhost' to view any web pages you place in the directory).
10. Next you will see a 'Browse...' button, click on this to select the directory your web site pages are in on your computer, after which click on the 'next' button to continue.
11. On the final part of the wizard you will see a series of boxes, if you are not worried about security then select them all, if you are and want to run ASP scripts then check the first two, followed by the 'next' button.
12. Once the virtual directory is created you can view the web pages in the folder by typing 'http://localhost/aliasName' (where 'aliasName' is, place the alias you called the virtual directory) into the address bar of your web browser (you can substitute 'localhost' for the name of your computer if you wish).
Oct 20, 2008 | Computers & Internet
Outlook Web Access (MS Exchange 2007)
I know some interesting tools which work with ms exchange files, but only one of it could help me in like problem and in my view it would relieve in this issue also - edb recovery.
Sep 05, 2008 | Microsoft Exchange Server 2007 Standard...
How to configure FTP server in windows xp prof ?
Setting up an FTP site Using Windows XP Professional Windows XP professional (as well as Windows 2000) includes Microsoft's IIS (Internet Information Server) which can be used to create an FTP site on your computer. It's a fair bit less complicated and less flexible than using some third-party FTP server software packages, so we will give you guides for setting up both. If you are using XP Home you will need to use third-party software. There is no way to publish an FTP site with the Home Edition of XP.
The first step is to check that IIS (Internet Information Services, Microsoft's web-server application) is configured properly.
Go to start\'control panel'\'add/remove programs'\ choose the 'add/remove windows components' button from the bar on the left. Highlight the item 'Internet information services (IIS)' If it is unchecked, check it, then click 'details.'
The components you will need are: 'common files,' 'file transfer protocol (FTP) service' and 'internet information services snap-in.' Uncheck any others then click next. IIS will configure itself, and you may be prompted for the XP CD.
Mar 21, 2008 | Microsoft Windows XP Professional x64...
5,180 people viewed this tip
David Payne
David Payne
