Tip & How-To about Computers & Internet
How to copy program using True Image
Acronis True Image allows the computer to back up the data. The programs can periodically back up the entire hard disk, either online or in another physical disk. It can also backup individual items, such as files, folders or programs.
1. In a clear picture, click "File backup" from the main window. "The backup file is opened.
2. Navigate to the folder in the program with the left panel. For example, if you want the program to copy folder with the software Menezes "in" Program Files "directory, navigate to" Program Files ".
3. Folder from the right window.
4. Select the destination of the "target" drop-down box. For example, if you program to a "D" of the secondary unit.
5. "Backup Now" button.
Computers & Internet Logo
i need acronis true image 11 home serial no
If you are installing a trial version of Acronis True Image Home 2011 or Acronis Disk Director 11 Home, you do not need a serial number.
If you have an OEM version of an Acronis product (e.g. preinstalled on your hard disk, notebook etc), please contact your OEM vendor for a serial key.
If you purchased your Acronis product online, then you should have received your serial number in an automatic E-mail that was sent to the E-mail address that you provided at the time of the purchase.
If you purchased your Acronis product offline at a retail store, then the location of the serial number depends on the package:
  • Boxed product, that consists of the CD, White CD Sleeve, Quick Start Guide. - The serial number sticker is affixed to the back of White CD Sleeve;
  • DVD Amaray Case, that consists of the CD and Quick Start Guide. - The serial number sticker is affixed inside the DVD case on right hand side. Directly above where the CD is held in place.
If you still cannot find your serial number, you can try contacting Acronis Customer Central here: http://www.acronis.com/support/index.html?ow=1
Apr 09, 2011 | Acronis True Image 11 Home: Windows
when i turn it on it just says-SMART HARD DISK IS ABOUT TO FAIL,BACK UP THEN PRESS F1 TO CONTINUE,MY LAP TOP WAS ALREADY PRE-INSTALLED WITH WINDOWS 7 SO I DONT HAVE INSTALLATION CD
Hard disks with S.M.A.R.T. technology have internal checks that may identify problems with your hard disk that may lead to fatal failures, warning yu in advance (it is very common when people hit or let their laptops bump against the table - hard disk drives are very sensitive to shocks and bumps...)
First of all: BACK-UP ALL FILES YOU CONSIDER IMPORTANT, SPECIALLY YOUR OWN  DOCUMENTS!
One way to solve your problem could be to download and install a 30-day trial version of Acronis True Image Home 2011 from http://www.acronis.com/homecomputing/download/  and use it to generate a full backup image of your hard disk into an external USB hard disk drive . Please, generate also the Bootable Rescue Media CD.
Then buy a replacement disk, install it in the laptop and use the Bootable Rescue CD to start Acronis True Image directly from the CD and recovery your backup, reinstalling everything back to your laptop, in just a few minutes.
Although using the trial version of Acronis True Image will help you in this emergency case, you might want to buy it as it is an exceptional tool to have for cases like this.
Another way would be to download all the drivers for the devices installed in your computer, save them in a CD or flash drive, buy and install a new hard disk, buy a Windows installation CD and reinstall your laptop from scratch, using the drivers you downloaded earlier to reinstall them to your laptop..
f you need further assistance, please, feel free to ask us here at FixYa.
Hope this info may help you.
Mar 19, 2011 | Computers & Internet
How Do I backup my computer, so if it crashes I do not have to reload every thing, and how offten should I backup?
The best way is to make a disk image of your hard-drive. I use Acronis True Image Home 2010. With this software you can save an image of your hard-drive to a second hard-drive or DVD's. It will even do automatic backups of your entire hard-drive or just documents. What I recommend is do a full backup as soon as your PC is just the way you want it with all the programs you use. Then do monthly backups of your documents.
Jul 15, 2010 | HP Pavilion dv6000z Notebook
Lost recovery dist for sony vaio pcv-rx500
I had an RX540 and I can tell you absolutely that you have NO options other than hopefully finding it in the classifieds. Sony is rigid about not only programs but also hardware that originally came with it.
You didnt mention you were having any problems right now so I assume all is up and running well? If so, I recommend 'ACRONIS TRUE IMAGE' its a back up program of my choice that lets you back up the entire operating system or just programs and you can back it up by making restore disk sets or simply cloning the whole drive to another drive. There are other programs that do this but I have tried a few and many times when you back up programs they will restore ok but then ask you for serial numbers. ACRONIS has only done that with one program that I have seen.
So simply..
search for a program that auto-copies all your serial numbers OR mark them down yourself and make some restore discs using Acronis or something similar.
I would also suggest cleaning any old files etc off your drive and running a scandisk and defrag before you do the back ups.(for good quality and speed)
When you back up.. back up the entire operating system AND all the programs.
If you only select operating system, all you will have is windoze.
In the future you can totally foul your windoze and simply boot to the Acronis recovery cd and the back ups ON CD and it will restore your computer.
Or.. do what I do. Once you have everything perfect, simply clone the entire drive to another drive and if it ever messes up just swap out the hard drive like changing a light bulb.*s* (always save your serials.)
By the way, a hard drive needs to be about 1/3 empty to work well and fast because there are windows memory and swap file issues. So free up some space for good performance ok ?
I hope this was helpful. good luck.*s*
Oct 25, 2008 | Sony VAIO PCV-RX500 PC Desktop
T30 2366 not recovering from original recovery disk
The 2 gig partition is probably your recovery partition that allows you to restore your computer from the hard drive instead of the Operating System discs that came with the unit. You don't really want to mess with your partitions (you may accidently delete all your data). I'd recommend using Acronis True Image and backing your data to an external hard drive first, you can copy individual folders or the entire hard drive. Then you can just destructive restore your entire hard drive back to factory settings.
May 06, 2008 | IBM ThinkPad T30 2366 Notebook
154 people viewed this tip
David Payne
David Payne
