Tip & How-To about Computers & Internet
How to recover data from a bad HDD
If a hard drive clicks and the information starts to move through them very slowly when it opens is stored, you need to store data as soon as possible. It's just a matter of time before the hard disk stops working completely. You can try everything from the freezer to remove the device, because the drives read better in colder temperatures.
1. Place the hard disk in a zip lock bag and freeze the zipper to close.
2. The bag containing the hard drive in the freezer. Cool in the freezer for several hours.
3. Remove the bag from the freezer. Remove the hard disk of the bag.
4. Connect the hard drive of your computer, connect the two pin connectors in the slots of the rear disc.
5. Click on the blue circle in the lower left corner of the screen. Click My Computer. Double-click the hard drive appears.
6. Click and drag the files from your hard disk to another disk or desktop.
Computers & Internet Logo
what is the use of RAM?
The ram is basically the speed memory, any programs open are saved to the ram while in use, the more ram the more things can run. Hope this helps :)
Jun 06, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
what is the difference between hard drive and solid state drive
SSD or Solid State Drive has no moving parts - while normal hard drive has. Just think about name.
Nov 30, 2010 | Computers & Internet
My Mac will not store data on my wd external hard-drive
Take it back to where you bought it, and get a replacement,
or at least get them to demonstrate that it _does_ work, when connected to a Mac computer (not a Windows computer).
Dec 26, 2009 | Western Digital Elements powered by WD 320...
Move data from one computer to another with kingston 8gb data tra
When you plug in the Flash Drive to your old computer, it will show up in My Computer probably as Removable disk or "Kingston Data Travler". You want to open that link up and drag whatever files you need into that folder. After doing so you put the flash drive in your new computer and repeat the process except you drag the files out of the folder and onto your desktop or a folder of your liking.
Jan 31, 2009 | Kingston (SDCZ2-512-A10-KT)...
Bytecc 2.5 Mobile HDD Hotdrive
Looks like you need to Format the new drive.
Your computer can see it, but cannot access it, right?
You can right click on the new E: drive and select the Format option.
If that doesn't work, then you must right click on My Computer, and select Manage from the pop up menu.
Then click on the option Disk Management at the left.
Soon you'll get a graphic view of the hard drives currently installed on your system.
Now just select the drive you want to activate E:\, right click on the rectangled area, and select FORMAT.
Once the process is completed you will be able to store information, pictures, etc.
Please don't forget to rate if the answer helps.
Sep 12, 2007 | Computers & Internet
4,882 people viewed this tip
David Payne
David Payne
