Tip & How-To about Computers & Internet
How to obtain public IP from Time Warner
There are two basic types of IP addresses of internet service providers (ISPs) to provide customers with Internet services: a dynamic address or DHCP and a static IP address. A static IP, as the name implies, uses the exact same IP, and you're online all the time. The DHCP IP configuration uses a "stack" of available IP addresses each time a modem is online and an IP address of the network of the ISPs is simply grabs the first available IP address from the stack. The IP configuration of DHCP, then it is very easy for a new public IP address from your provider at any time
1. Unplug the cable modem from Time Warner. Total count of 30 seconds and close.
2. Allow the modem to reboot every five minutes. During this time, goes through the boot cycle, contact your provider and ask for a dynamic IP address.
3. Navigate to the computer's IP Configuration Manager. For most versions of Windows, the easiest way to do this is to open the Start menu, click All Programs, then select "Command Prompt" from the "Accessories" menu (for future versions of Windows, you may need to the right button on the Command Prompt and select Run as Administrator "to show itself sufficient permissions on IP of the computer information).
4. IP address to test your computer by typing "ipconfig" and "Enter" Command to the numbers printed next to "IP address", like "IPv4 or IPv6 address." The number displayed on the public IP address of the DHCP as the modem from Time Warner will receive net.
Computers & Internet Logo
what is the ip address
IP address
noun Computers. a code that identifies a computer network or a particular computer or other device on a network, consisting of four numbers separated by periods. See also IP.
http://dictionary.reference.com/browse/IP+address
PS. Free points for newcomers or are you to lazy to google it?
Aug 23, 2013 | Comtrend CT-520 Router
what is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
dinamic ip address
  1. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online,
  2. Type admin for User Name, and password is blank. (do no type any thing for password.)
  3. Click OK. This logs you into the router.
  4. Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
that would fix your problem..
in case if yoy have any problem revert back with your internet service providers name.(isp).
Feb 09, 2008 | D-Link DI 514 Wireless Router (DI-514)
2,434 people viewed this tip
David Payne
David Payne
