Tip & How-To about Computers & Internet
How to make back up of your software settings
Software settings on your computer are stored in the Windows registry. To create a backup of these preferences is made a system recovery. A restore point takes a snapshot of your registry settings and stores them on your hard drive. These restore points when using a plant damaged registry settings that result in errors pop up every time the computer. Windows provides an interface to quickly create a new restore point.
1. Click the Windows Start button. Click "Control Panel" to a new window. Click System and Maintenance link. "Click" System "to the system settings.
2. Click "System Protection", for the utility, create a restore point. If you are not logged in as administrator, a pop-up asking for the password. Enter your password and click OK.
3. Click "System Protection" tab. In this window, click Create a new window. Enter a name and description for your restore point, so you can see the backup. Click Create to create the backup software.
Computers & Internet Logo
eMachine EL1850-01e
It looks like you'll have to either return it or perform a default factory recovery. These instructions are from their site but proceed knowing that this will erase any data that is stored on the primary partition (meaning if you have anything on it, it's gone...). Esentially it resets it to a point as if you just picked it up in the store (which you did.. :( )
How can I restore my computer with the backup discs I created?
With user created backups you are able to restore your computer to the factory default settings. If backup discs were created instead of factory restore discs, these can be used instead and will restore the system to a user backup point.
    If you have a recovery disk:
    1. Ensure that the computer is completely shutdown, then turn on the computer.
    2. When the eMachines splash screen appears, tap the Alt and F10 keys simultaneously. A screen stating "Starting eMachines eRecovery" should appear.
    3. From the recovery options, choose Restore system from CD/DVD.
    4. Insert either the first Recovery or Backup disc that you created.
    5. From the on-screen options, choose a backup.
    6. Click OK and the installation will begin.
    7. Change the disc as necessary when prompted.
      If you do not have a recovery disk:
    8. Restart the computer.
    9. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
    10. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
    11. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Dec 13, 2011 | E-Machines eMachines Desktop PC
My laptop will not boot, instead it goes to a blue screen that states it is not able to access the hive.
I think this is the exact error : Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION:
To resolve this issue, please follow one of the following methods.
Use the Recovery Console Tool:
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console. You need your original XP CD, boot your PC from the CD and press R when it say 'Press 'R' to use recovery console.
In Recovery Console, change to the c:\Windows folder.
Type cd system32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
i understand this looks a litle daunting, please get back to me if you have any trouble with this.
Oct 16, 2010 | Sony Computers & Internet
how do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
restore3
I found these instructions for you on the Sony support site.
Solution
sp.gif sp.gif IMPORTANT:
  • Before performing a recovery, go to the Sony® eSupport Web site at http://esupport.sony.com and check your model-specific support page. Look for software and driver updates or check for knowledge base solutions that may help you solve your computer's issue.
  • This model does not require Recovery CDs. Recovery data is included on a special partition of the hard drive.
  • Do not interrupt the power during the recovery process.
  • Before performing a recovery, disconnect any external devices not supplied with the computer such as printers, network cables, cameras, or external storage devices, like hard drives or flash drives.
  • Customers who purchased the Symantec® Norton Internet Security® 2007 software from the Sony Style® store with their computer must create a Norton Account to save their product key prior to a system recovery or the software cannot be reinstalled.
NOTES:
  1. Click the Start button, then click Help and Support . NOTE: If the Help and Support link is not available on the Start menu, re-enable the link in the Taskbar and Start Menu Properties window.
  2. In the Windows Help and Support window, click Backup & Recovery .
  3. Under Backup & Recovery , under VAIO Recovery Center , click Launch VAIO Recovery Center .
  4. In the VAIO Recovery Center window, under Choose a program , click to select the desired option:
    NOTES:
    • It is strongly recommended that recovery discs be created to help restore files if the operating system will not start. Recovery discs are bootable and can be used to perform a recovery on a properly functioning hard drive.
    • The Windows Backup and Restore option opens the Backup and Restore Center provided with the Microsoft® Windows Vista™ operating system. This provides the ability to save information from the hard drive, such as personal data files, and restore previously backed up data.
    • Computer problems related to hardware can be diagnosed using the VAIO Hardware Diagnostics option.
    • One or more drivers or factory-installed applications may be reinstalled with the Reinstall Programs or Drivers option.
    • The entire (C:) drive can be restored to its original, factory-installed condition by selecting Restore C: Drive .
    • Choosing Restore Complete System will restore the entire (C:) drive, while removing or restoring the Recovery Drive partition. Modifying the size of the hard drive partitions is also an option with this type of recovery. This option requires you to insert Recovery DVDs created using the Create Recovery Discs option.
    • To remove all data from the hard drive, including the operating system, all programs and personal data, choose the Wipe and Erase Data option. This option is provided for the convenience of advanced users who want to install a different operating system, and who want to ensure all data has been removed from the hard drive first. All other users are strongly urged to avoid selecting this option.
Please update me on the same.
Regards
Sammy
Jul 10, 2008 | Computers & Internet
127 people viewed this tip
David Payne
David Payne
