Tip & How-To about Computers & Internet
How to change an Am2 socket to a 939
1. Connect the computer operating system and save up to five minutes waiting for the AM2. Unplug the power cord plugged into the computer and the cables for each of the other components of the computer case.
2. Put the computer case on its side on a flat surface. Unlocking the computer side panel by removing the case screws on the back wall. So remove the lid of the box that the motherboard is visible.
3. In the Annex, the power of large space in the upper left corner of the computer. Unplug the power from the motherboard. Find the positions of the rectangular, green RAM module on the right side of the fan on the motherboard.
4. Slide the plastic lock down on both sides of the RAM module and remove the module from the motherboard. Repeat the process if necessary, if the computer two or more RAM modules. Find the card with the lower left corner of the motherboard.
5. Remove the screw holding the end of the metal rod of the expansion card on the back of the computer. Pull the card and remove them from your computer. Repeat the process if you have two or more expansion cards on the motherboard.
6. Disconnect the cable from the plastic fan on the motherboard. Slide the side guides of the fan and remove fan and heatsink metal AM2.
7. Pull the handle to the right of the issued AM2 processor. Pull the CPU and the motherboard removed. Remove the screws in the corners of the plate and slide the motherboard, right.
8. Lift the motherboard of the computer case. Place the socket 939 motherboard inside the chassis and drive expansion ports and power with the holes on the back of the case. Press the board to stick to the left and the screws on the motherboard in place to replace.
9. Set the Socket 939 processor socket on the motherboard and reconnect all processor pins on the base contact. Slide the locking arm and spread a layer of thermal cooling of the processor with the applicator stick.
10. Connect the power cord and insert the RAM modules and expansion cards for the new motherboard. Put the lid side of the computer and reconnect all cables.
Computers & Internet Logo
Won't read, play, or store music.
Performing a product reset To reset your system, follow these steps:
  1. Turn your system off. Wait until "Saving your music information" disappears from the display
  2. Unplug the AcoustimassĀ® module power cord from the power outlet
  3. Wait 60 seconds
  4. Plug the Acoustimass module power cord into a working power outlet
  5. Turn the system on
Note: After the reset, wait several minutes before playing stored music (stored music may not be immediately available depending on how many CDs have been stored). All other sources are available, immediately after the system is turned on.
Feb 06, 2016 | Bose 3 2 1 GSX System
Run then stop after five minute
Check the reset/off circuit breaker. If the circuit breaker has tripped, wait for five minutes and then press the switch to the reset button.
You want the switch to be on reset, make sure that the power cord is plugged in. If the power cord is plugged in, unplug it, wait for five minutes, and then plug it back in.
Remove the key from the console, reinsert the key into the console.
These are just a few basic steps and if it does not solve the problem please do not hesitate to get in touch with our Technical Support Team by chat at www.sportsmith.net or by phone at 888-713-2880 we would be happy to help you further solve the issue. Hope this helps and we look forward to hearing from you :)
Aug 11, 2015 | Nordic Track Exercise & Fitness
install power supply
No Power on an HP Pavilion PC Desktop b> Desktop computers are simultaneously more complex and easier than laptops when it comes to troubleshooting. There are more physical components on a desktop, so locating a specific troublesome part can be tricky, but working inside of a desktop computer is straightforward compared to opening and fiddling with a laptop. Power problems are always hardware problems. There are a few simple, preliminary steps to troubleshooting, but power problems often require opening your computer and having a look inside.
The Basics
Unplug everything from your PC except for the power cord. Try turning on the system and look for lights on the front, then on the back. When the power supply is on (receiving power), the small light beneath the plug turns green. If this light doesn't come on, the problem is either connected to the cord or the power supply. Try swapping power cords with the monitor cord to isolate the cord as the source of the problem. Look closely at the voltage selector and make sure it's set appropriately for your country -- 110 in North America and 220 for most other regions. b> The Socket b> Unplug the power cord and switch the voltage selector to the opposite setting. Wait five seconds, then flip it back. This ensures that the switch is engaged. Plug in the power cord again and try turning on the PC. Check the outlet to make sure it's working, and plug your computer direction into the wall socket (remove it from any surge protectors or power bars). Check the power button. If it sticks when you push it, it may not be making contact to engage the system power and will need to be replaced. If the button is going in and out freely, you've done about everything you can do from the outside of the computer. It's time to go inside. b> Open it Up b> Unplug the power cord and hold down the power button for five seconds. This clears all electrical charges from the circuitry and makes it safe to open the computer. Remove the side panel from your system. This process varies a bit from model to model -- some have one or two captive screws on the back of the system, some have an easy release button. Check your manual. b> Power Button b> Locate the power button from the inside and trace the cables to where they plug into the motherboard. Lift up on the connector and then push it firmly back down. Plug the PC back in to its power source and try to power it on. Unplug the computer immediately if the system doesn't power up, and continue troubleshooting. b> Hardware Components b> Disconnect each of the devices in your computer one at a time to locate a faulty piece of hardware. Power cables run from the power supply connect to your optical drive, hard drive, floppy drive (if one exists) and into several places on the system board. This step takes some trial and error detective work and a few minutes: unplug one device, reconnect the power, and try turning on the system. Then disconnect the AC power, plug the device back in and try the next one. If the system powers up at any stage, the device you are unhooking is shorting out the power and needs to be replaced.
http://www.youtube.com/watch?v=HJvYGtbwmh8 To Replace HP Pavilion Desktop Power Supply http://www.youtube.com/watch?v=VcEFUpZSmI4 Hp Pavilion 750n desktop computer basics on this computer b> http://www.youtube.com/watch?v=D8Y2PPMiiB0 HP Pavilion Slimline PSU Upgrade Guide This guide compares the Sparkle SPI270LE - 270 watt PSU against the Shuttle PC50 -300 watt as possible power supply upgrade for a HP Slimline. The s3600t Slimline I used for this video has a Intel Hope this helps.
Jan 03, 2013 | HP Pavilion 761n PC Desktop
error 5400
Solution: Press ON/OFF switch and wait a few minutes before powering back on the device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear an error, power off the printer and power it back on. Before powering back on the printer, wait five to ten minutes.
  1. On the operator panel, press the <ON/OFF> button. (The display will go blank.)
    Note: On rare occasions, it may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately five to ten minutes and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
FYI - There is a firmware update for this unit as well
Apr 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
computer stopped receiving wireless router signal
In this order: 1) Turn off all PCs and printers connected to the router. 2) Unplug your router's power cord. 3) Unplug your modem's power cord. 4) Wait for at least 2-3 minutes. 5) Connect the modem's power cord and wait for at least 2-3 minutes. 6) Connect the router's power cord wait for at least 2-3 minutes. 7) Turn on each PC separately and wait until it is completely finished booting before turning on the next PC.
If you still do not have connectivity, read the manual and change the channel of the modem. YOu may be experiencing some RF interference, ie microwave, wireless phone system etc...
Oct 29, 2008 | Linksys Wireless-G Broadband Router
264 people viewed this tip
David Payne
David Payne
