Tip & How-To about Computers & Internet
How to troubleshoot an electrical brownout (computers)
Modem router and switches
1. Plug the device into the outlet and see all the lights. Determine if they are all about how they should turn.
2. Disconnect the device from the device and allow to rest for five to 10 minutes you can Sun
3. Turn off the lights of the device into an outlet and a view of the screen to see where we are going. When you're gone, then the Brownout the unit is damaged and needs replacement.
Computer
1. Disconnect the computer from the electrical outlet and turn it so your back is turned.
2. Locate the AC adapter to the top of the PC, the rear fan. Near the fan and see if a burning smell.
3. Connect the power cable from the PC and turn on the computer. Hear the sound of the computer. If you do not hear and determine that there is a smell of burnt food, replace the power supply.
4. Open programs and working on the computer. Look to see that the freezing tissue damage your computer or network restart.
5. Listen to the fans to operate. If not the fan or the hard disc, that harm could be caused by a voltage drop.
6. Open your Internet browser and try online. If your computer is not connected to the Internet, and you're using a wired connection, unplug your computer and check the NIC light to see when it flashes. A light no flashing is an indication of a failed network card. Check the lights on the modem, router, switch and hub. If all lights are working, but the computer will not connect to the Internet, this means that the board brownouts wireless network or affected. You must replace the device failed.
Computers & Internet Logo
security
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jul 23, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
i cant connect to the internet
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
INetwork Password
ask your internet service provider
May 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
how to change password
1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
i have a wireless router i can get it working right?
How to quickly install and use your wireless router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Apr 26, 2010 | Airlink AR430W Wireless Router
185 people viewed this tip
David Payne
David Payne
