Tip & How-To about Computers & Internet
How to back up SME server to a USB Drive
When you click your home network through a server for SMEs running, you may be used for storage for all computers on the network. All computers on the network access to these files, but are incapable of data relating to a different computer, not on the SME server to take. So it's a good idea to back up server data on a USB flash drive.
1. Current in a computer systems and network to log on as administrator. This action gives you full access to all files on the server disk SMEs (not only files of a particular user is stored) is stored.
2. Connect the USB key into a USB port on your computer. Click Start and My Computer. Double-click Removable Disk. This action loads a window with all files stored on the flash drive. Leave the windows open for the moment.
3. Back to "Computer". Double-click the drive of the SMS server. A window with the files on the disk, unless the network server.
4. Click and drag the files from the open window on the USB flash drive appears. This process ensures that data from the server window on your handheld.
Computers & Internet Logo
My ditto status led is off and I get error 301 when connecting my ditto.
Is the Network Server connected to something? Contact me if you require help.
Nov 05, 2013 | Dane Elec 1Tb Myditto 2-Bay Home Network...
how to change the server aol to my google chrome on start up
Dynamic host configuration protocol (DHCP) is a way to configure IP addresses and TCP/IP settings throughout your network.
The DHCP service is run on a machine with a static IP address so that the computers on the network can find it for automated configurations.
Setting the IP address on a Windows 2003 server is accomplished through the network configuration settings in Control Panel.
Click the Windows "Start" button and select "Control Panel." Double-click "Network Connections." In this section, double-click "LAN Connection."
This opens the configuration tool to set the IP address of the server.
Select "TCP/IP" from the list of configured network applications and click the "Properties" button. This opens a new configuration window.
Select "Use the following IP address" to set a static IP for the server.
Enter the IP address chosen for the server in the first textbox that is activated.
Enter the subnet mask and default gateway for the server.
The default gateway is usually the router on the local network or the DSL or cable modem on a small, home network.
Enter the DNS server address.
The DNS servers are separate servers on the network.
For small, home networks, the DNS server is provided by your service provider.
Click the "Ok" button to save the settings. Click "Ok" again at the general LAN properties window.
Renew settings on local computers. Computers that use the DHCP server for configuration need to be rebooted.
You can also use the DOS command prompt to renew settings.
The "ipconfig -renew" command refreshes the settings on client computers on the network.
or for home page browser
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have
have if dont need any of them you can disable or remove them
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
Hope this helps
Dec 29, 2012 | Google Chrome
Storage Server Mapping Issue
Check that the DNS servers used by both the LAN & WLAN are the same.
Mar 25, 2009 | Computers & Internet
Toshiba Magnia SG20
do you have an admin icon on your desktop?
if not type in the ip addx 192.168.1.1 and see if you go to the admin.
on network connections , right click on my network places, click map network drive,
select a drive letter and then browse for the two folders on the "myserver" select one of them and click apply or ok. the drive will show up in mycopmuter do the same for the other folders
as far as the log in is concerned it is best to set a level 3 user name and pw on the server then do the same user name and pw for a new windows login user.
Nov 20, 2007 | Computers & Internet
1,314 people viewed this tip
David Payne
David Payne
