Tip & How-To about Computers & Internet
How to computer capture a sound card
Record and recording the sounds through the computer sound is a relatively simple procedure that only a free space on the hard disk, suitable software and a short profile of TRS cable is required. Windows computers usually come with an audio recording program, from the entertainment equipment a program is found in the Start menu.
1. Turning off the computer speaker's audio jack of your computer's sound card.
2. Attach the small RCA cable into the sound card speaker output.
3. Connect the other end of the RCA small correction to the microphone port on your sound card.
4. Start the Sound Recorder program from the Start menu. Click the Record button. Tell your computer to the sound you want music or video progress bar to take to indicate when the movie is ready to play. Click the Record button, which will continue to record.
5. Click the File menu in the Sound Recorder program and select "Save As". Enter a filename and click Save.
Computers & Internet Logo
How to record and how to connect to computer how long does it record
sound , which can be found on windows records for as long as you want I think. Bearing in mind that a file is created that is stored on your hard disk then the size of file that is created must be smaller than this. I voice record a fair amount and sometimes record a couple of hours from the radio here in the UK. If you have a huge hard disk , say 4tb , you should be able to record thousands of hours of audio. One thing...if you do record editing is dificult if you make the files too long.
Good Luck
May 29, 2015 | Audio Players & Recorders
preamp how to
20/20 refers to decibel output from the preamp, relating to your condencer mic. 24/96 or 24 bits/96 khz is the quality of the sound. It is considered the best resoultion, but uses up more memory ( space) on your hard drive than 16 bit. If you have plenty of space I would record at 96 k
Apr 19, 2014 | Audio Players & Recorders
i have a pinnacle dazzle converter, but when i record a movie it will only allow me to record up to 103 mins. why is that?
May be you don't have enough free hard disk space. Increase the free hard disk space and check.
All the best!
Sep 21, 2011 | Pinnacle Dazzle DVD Recorder
Memorex DVD-RW (4X 4.7GB) disks keep closing record sessions and cuts off at about 1:39 minutes.
Hi. Sounds like you are maxing out your recording space on your disc.1:39 sounds like the capacity of a single layer DVD-RW. You can confirm this by putting the disc into a computer and checking the "properties" of the DVD. Go into "My computer" [ldouble click], highlight DVD drive [rightclick] then select "properties"[left click]. the pie chart will show you graphically space remainig on the disc
Mar 17, 2010 | Sanyo DRW-1000 DVD Recorder/VCR
DV-PC recorder
DV-PC Recorder is a Windows XP only application that enables you to record images and sound on the tape in the camcorder and on the computer's hard disk by connecting a camcorder equipped with the DV CONTROL function to a computer using an IEEE1394 (DV) cable. DV-PC Recorder has the following features. 1. You can record movies simultaneously on your computer's hard disk and on the tape by pressing the start/stop button on the camcorder. 2. It enables long, continuous recordings, which you cannot achieve with the tape alone. (Approximately four and a half hour's worth of recording will fit on a 60GB hard disk.) 3. You can start editing the movies on the computer right after recording, as the images and sound are saved on the computer's hard disk. (Optional editing software is required to edit movies) 4. You can record movies on the tape in the camcorder and on the computer's hard disk by controlling the DV-PC Recorder from your computer.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
2,134 people viewed this tip
David Payne
David Payne
