Tip & How-To about Computers & Internet
How to make an Image of your HDD Partition
Backing up your computer is extremely important. Without it, it would be a hard drive failure or corrupted file may cause that you lose all your data. When these disasters may also lose valuable time in the operating system and reinstall the software before returning to work. Avoid loss of data and loss of time by an image from your hard disk or partition. When a problem occurs, the train ensures their unit begins to replace the computer and continue working.
1. Install the image or backup software. If the software is downloaded, double click the downloaded installation file and follow the instructions on the screen. If you have the boxed version, insert the CD into the drive and follow the onscreen instructions.
2. Connect your external hard drive and open the software by double clicking the icon on your desktop. If there is no icon on your desktop, click Start, Programs, and click the name of open source software.
3. Click "Backup Drive" near the center of the screen in the software.
4. Click on "Switch to partition" in the upper right corner of the screen only one partition, or click the "Switch on your hard disk to back up the entire disk.
5. Check the boxes next to the disk you want to record to select.
6. Choose your external hard disk in the "Target" box in the middle of the screen and "Back Up Now" click the button below to start the backup process.
7. Separate additional hard disk and place in a safe place, ready with the primary hard drive in case of emergency.
Computers & Internet Logo
I purchased a product to fix my laptop which has a corrupted hard drive, but whilst downloading the laptop crashed, I managed to get it going in 'safe mode', but could not find the product in the 'dow
Their are no software products to fix a crashign harddrive.
Many scams out there claiming to bve able to sell you one.
run antivirus , to clean up harddrive, or reformat hard drive to see if it is still functing.
Jul 02, 2014 | Packard Bell Computers & Internet
I have a emachine unplugged it plugged it back in now its telling me to reboot and I can't get my computer to work how can I reboot without disk?
It sounds like your hard drive is not being recognized. I hope you didn't unplug it while it was still turned on as that can cause hard drive corruption. The hard drive or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Good Luck
Jun 23, 2014 | Computers & Internet
BOOT MGR File is missing CTRL ALT delete to restart computer
This can happen for several reasons, hard drive failure, deletion of a needed file, format the hard drive, removal of a hard drive, or virus causing corruption on the hard drive. Without knowing which of these it is, it would be very difficult to tell you how to fix it.
Jul 29, 2011 | Computers & Internet
my harddrive was accidently unplug without exiting properly and files may have been open.
Chances are that some files have been corrupted or the hard drive is corrupted.
If you are lucky the hard drive is OK and you may have lost a few files. Connect the hard drive to your computer and check your data.
If the hard drive is corrupted, you may have to format it to get it operating again and you will lose your data.
Mar 01, 2011 | Computers & Internet
can i format sata hdd without loseing my files
partition magic may do it, but chances are not. in order to change a filesystem, you have to erase all data to avoid compatibility issues. some file systems have file size limits or even file name character limits and doing a format without erasing the data can corrupt the drive to the point where the data is unable to be recovered. I always recommend backing up data first and would never even try a format without backing it up.
Jun 10, 2009 | Fanner MASSCOOL 3.5" PATA and SATA hard...
265 people viewed this tip
David Payne
David Payne
