Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Join/Combine Canon HF M300 AVCHD MTS raw footage-Stream Canon MTS to Panasonic TV for watching
Best Mac Manage MTS Converter-Cut and Join Canon HF M300 AVCHD MTS clips to Panasonic HDTV with Highest Qulity
I am using Canon HF M300 to record videos and the camcorder saves AVCHD files in .mts format. The Canon VIXIA HF M300 captured 1920 x 1080 24Mbps Full HD Recording. I connect the Canon Camcorder to my Panasonic HDTV via direct USB. However, I found my shooting video of the HF M300 have some pause and interlace in the process of recording. So I need to delete much unwanted mts clips and join into one big files. So I asked for some help on some forums and was recommended to try freeware TSmuxer, TSsniper which can help me to Split and Merge AVCHD MTS files. But it is frustrated for Mac users because most of them can only work on Windows platform. Then one of my friend recommended to a new MPEG-4 AVC/H.264 cutter/joiner software for Final Mate for Mac exactly what I want - delete the unwant .mts clips and merge HF M300 1080/60p meaningful MTS files to one single MTS files without re-encoding. And I had succeed play those merged .mts files on my Panasonic TV.
Here is the detailed guide introduces how to split unwanted HF M300 record AVCHD .mts clips and join meaningful mts clips without conversion for playing on Panasonic HDTV with Mac OS X Snow Leopard on iMac, MacBook, Mac Pro.
Step 1: Import/Capture Canon HF M300 Camcorder AVCHD files to Aunsoft Final Mate for Mac.
Free Download Final Mate for Mac as a Best Mac Manage MTS Converter. When Aunsoft Final Mate for Mac is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab.
Step 2: Create a Movie for cutting and joining HF M300 1080/24Mbps MTS clips.
Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split, join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created.
Step 3. Cut off unwanted parts from raw MTS movie for store.
From the timeline, to cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the "Delete" button next to the Split button to remove the unwanted. And the Previous Frame and Next Frame buttons can help you locate each frame of the videos and cut with frame accuracy.
Step 4. Join/combine HF M300 AVCHD MTS raw footage.
To join another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output.
Step 5. Export One Big raw HF M300 MTS with no loss of quality.
Click the Export button and you click the OK button, the Mac MTS/M2TS cutter/joiner will start merging large .mts files into one mts without conversion at the fast speed. The non-conversion process will prevent loss of quality when Mac joining HF M300 avchd camcorder files for storing.
After a few seconds, I Connect Canon Camcorder Movies to my Panasonic HDTV via direct USB. Then Stream Canon HF M300 MTS to TV for watching with family. The output mts also can store the video on your home server, NAS or external hard drive.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Convert/Import, Edit Canon VIXIA HF Series Video to Mac, iMovie, Quicktime
Thanks for this useful post. But the way I make my AVCHD files from camcorder playable or ediatble is converting them to some common video formats, like AVI and MOV are my widely used. As for AVCHD Converter, I am using Aunsoft MTS Converter which helps me convert MTS and M2TS video files to MP4, MPG, WMV, AVI, and enables you to enjoy movies on computer or WMP, to further edit video for creation, to present video on HDTV, and to publish video online in web-friendly format. It makes your AVCHD camcorder videos editable on Adobe Premiere, Sony Vegas, Window Movie Maker, DVD Maker. http://www.aunsoft.com/mts-converter/
Oct 13, 2010 | Computers & Internet
Put and Play Canon HF S21 HD 1920x1080 AVCHD MTS on iPad Canon Vixia HF S21 is the new AVCHD camera in 2010 for capturing Hi Def 1920x1080. The 64GB internal flash drive enables long time video recording for more than 8 hours with Full HD 1920x1080 recording at FXP profile. It enables double slots for SD memory cards. The video captured with Canon HF S21 is stored in AVCHD .mts file format with MPEG-4, AVC/H.264 as video codec, and Dolby Digital 2 channel (AC-3) as audio codec. If you get the with optional Canon SM-V1 5.1-Channel Surround Microphone, you can get Dolby Digital 5.1-channel for the audio. To transfer Canon Vixia HFS21 AVCHD to computer hard drive: You can use the bundled Pixela ImageMixer 3SE Video Editing Software, and it is easy to transfer Vixia HF S21 AVCHD movies onto computer hard drive with this software. If you are using Mac computer, you can also use iMovie to download videos to Apple hard drive. Just connect the camcorder to iMac/MacBook Pro with Mac OS X like Snow Leopard, and HF S21 could be recognized by iMovie for loading videos. To put and play Canon HF S21 AVCHD videos on iPad: Even though iMovie mentioned above could recognize Caonon HF S21 for loading videos, there are also problems for importing Canon HF S21 .mts to Final Cut Pro (FCP) or Final Cut Express (FCE), even iMovie. Aunsoft MTS/M2TS Converter for Mac is the recommended Mac Canon HF S21 MTS to iPad converter for you to easily edit Canon HF S21 videos and transfer edited video to iPad. Below are the simple steps for transcoding Canon HF S21 to iPad. Step 1. Load Canon HF S21 video to Aunsoft MTS/M2TS Converter for Mac. After transferring Canon HF S21 AVCHD videos to Apple hard drive, run Aunsoft MTS/M2TS Converter for Mac as Canon MTS converter and click the "Add" button to load .mts videos. Step 2. Edit Canon HF S21 MTS videos. Select the video clip and click the "Edit" button to trim and crop videos, to flip video, adjust brightness and contrast. Step 3. Choose iPad HD output format. Click the "Format" option and choose iPad > iPad HD Video(*.mp4), and the Mac Canon MTS to iPad converter will convert AVCHD Hi Def 16x9 to 720p MP4 videos for iPad. Step 4. Convert Canon HF S21 MTS to iPad. Click the convert button under the preview window, and the conversion from Canon HF S21 MTS to MP4 for iPad starts immediately. After the conversion, connect iPad to iMac/MacBook Pro and sync the editing videos to iPad. It is that easy to transferr edited video to iPad. Give it a try and enjoy AVCHD videos on iPad.
Jul 29, 2010 | Cell Phones
1,279 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
