Tip & How-To about Genie Company IntelliCode GICT390-1BL Remote Control
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.
Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.
To Program Receiver
Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.
Step 2-2 Press a Transmitter Button once within 30 seconds.
Step 2-3 Press and release the Learn Code Button
• The Radio Signal Indicator will blink approximately 2 times per second.
• The Radio Signal Indicator stays lit - SOLID.
Step 2-4 Press the same Transmitter Button within 30 seconds.
• Radio Signal Indicator will go out.
NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.
Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.
NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.
Multi-Button Transmitters
NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.
NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.
Erasing All Receiver Memory
Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.
ALL Transmitter Codes are erased from Receiver memory.
Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).
Step 5-1 Battery replacement
• Slide Battery Cover off of Transmitter back.
• Replace with new batteries.
• Slide Battery Cover back on.
Step 5-2 Visor Clip installation
• Slide Visor Clip into back of transmitter until it snaps into
place.
Genie Company IntelliCode GICT390-1BL Remote Control Logo
I fried my 1400xp, so I purchased a used on on Ebay. How do I program my remotes to work with the new brain?
To program new remotes: turn key to the on position; within 10 seconds, press and release the programming switch one time. Press the switch once more and HOLD. While holding the programming switch, press and release the lock button on the new transmitter. Once the code is learned, the programming switch can be released. Turn ignition off. Test remote. Repeat as necessary for other transmitters.
Nov 24, 2010 | DEI Python 1400XP Remote Start/Keyless...
1,300 people viewed this tip
Top Genie Company Televison & Video Experts
Dan Apthorp
Leonard Manamela
Leonard Manamela
Are you a Genie Company Televison and Video Expert? Answer questions, earn points and help others
