Tip & How-To about Lands Phones
How to connect bluetooth keyboard to Android 2.2 Phone,Tablet.
Well you have a Phone, or a Tablet, and it's a touch screen, now touchscreens are all good, but sometimes one wants, needs? real keys, and a Bluetooth Keyboard should be the answer, but if like many of the people that try to connect a BT KB, to Android phones & tablets, well many, will not actually connect correctly and work. They say ....connected, or ....paired, but they actually aren't connected and one cannot type.. Well if this is your problem, then I may have found the answer, what you need to do is this go into the Settings and go to Wireless, and then Bluetooth, now activate the BTsearch for the, "Device" ie: Keyboard, and at this moment also activate the Bluetooth Keyboard itself's on/off switch, and then hold the pairing key until the LED goes blue and flashes, now, the phone will/should alert you to the fact that you have a "Pairing Request" In the Notification Bar, now, answer this request, quickly, open the Notification Bar, select, and then type in the "Pairing Key", usually Four Zeros 0000, now quickly, go to the keyboard itself, and type in Four Zeros 0000, followed quickly by the "Enter Key"... this is the trick, doing it "Blind" as it were, Now the Phone, Tablet should then indicate it has "Paired" and "Connected" and can be used Also you should see a symbol in the Notification Bar, and the BT Icon will also change to the "Connected" version. Now you will/should be able to use it, just like your touch keypad, in fact in some devices, you can use either at the same time...
I also installed a few apps drivers too, some these may also have assisted me i don't really know, but here they are,
http://www.teksoftco.com/storage/download.php?product=blueinputandroid_apk_18203
http://forum.xda-developers.com/attachment.php?attachmentid=470103&d=1292962995
http://forum.xda-developers.com/showthread.php?t=869747&page=6
The files on the xda site, have 3 files in a zip, you need to unzip these and drop them into the system/xbin, and CHMOD them all 4755 (I usually just 777 all) Use Root Explorer, or ADB, or a Terminal, to do this, after this reboot.
Remember if you don't get a connection or it drops out etc, you will most likely have to reboot, to reconnect, it's a quirk of the BT software i think, it's a pain, but maybe 2.3 will have it all worked out?
Lands Phones Logo
tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Jan 11, 2016 | Tablets & eReaders
EMATIC EWT935DK Touch Screen doesn't work.
sometimes the screen just glitches on any device that has touch screen if there is no reset pinhole on the device anywhere you may try to hold power and volume up until it restarts sometimes that can solve the problem I have to so this to my Galaxy S4 Active sometimes
Nov 04, 2015 | Tablets & eReaders
Touch screen not working / not registering touch
Follow the steps mentioned below until your problem is sorted.
1. Restart Your Android Device It works 80% of the time. Screen locking/managing applications often make touchscreen unresponsive. In that case you need to restart your Android device. How can I reboot my tablet, the touchscreen is not working.. Good question!
  • Grab your Android tablet/phone
  • Press and hold the Power Button for 10 seconds or until the screen goes blank.
  • Wait a minute or two and then power on your device normally using the same button.
2. Eject Memory Card and Sim Shutdown your Android device and remove the Memory card and Sim(s) attached to it. Also, remove the battery for few seconds if possible.
3. Remove Any Cases Smart cases are good in protecting your device from scratches and damage. But their automatic screen wake/sleep feature sometime cause the device to malfunction. Remove the case, perform a restart.
4. Hard Reset your Android For advanced users. If everything else doesn't work, try doing a hard reset on your phone. This will wipe your phone/tablet and return it to its original condition. This usually involves holding down Volume-Up and Volume-Down button together and then pressing Power Button (every phone has different method). It starts your device in Recovery mode, you can do a Wipe-Factory-Reset from there. Use volume up/down buttons to navigate and press Power button to select. Be careful and don't mess with other options or you may brick your phone.
5. Knocking the Touchscreen (Not recommended) Remove the Screen Protector on your Android device if present. Now, gently knock every corner of your touchscreen to realign it. Sometimes continuous phone drops cause screen digitizer cable to loses its connection to device motherboard however, its a rare case.
If you are still unable to make touchscreen work maybe its time to claim warranty, Its a lengthy process but works. Also, post comments below to share other tips not mentioned in this article.
May 29, 2015 | Cell Phones
How do I get my trio to go back to the home screen?
It could be that your touchscreen (digitizer) is PARTLY broken.
To confirm, try rotating your tablet 180 degrees, and then touch the home button again.
If it works when rotated then you need a new touchscreen.
I hope you are good with precision tools, and have good mechanical skills and instincts: it's a rather intricate job to locate the locking tabs and screws that attach the touchscreen to the insides of the tablet, then remove them, and finally to replace a touchscreen. And then reattach all necessary fasteners, and test whether it will work properly.
EASIER FIX: go to Ebay and buy a used Trio tablet. it may cost you only $40 to $50 maybe even less!
Sep 27, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
my v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
3,531 people viewed this tip
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
