Tip & How-To about Computers & Internet
How to Remove a AMD Processor
Removing a processor AMD is a work that can only be done with a screwdriver in less than 30 minutes. The processor AMD is a central processing unit (CPU) with 939 pins, which are connected to the motherboard. Removing the processor is an issue to withdraw from the motherboard with your hands after you remove the heatsink from the chip.
1. Turn off the computer and unplug the power cord before removing the AMD processor. Unplug the connector on the back of the computer case and remove the screws, the lid of the computer, in the case with a screwdriver.
2. Slide the computer cover and set aside. Pull the cord that connects the heatsink fan on the motherboard with one hand.
3. Lift the lever on both sides of the fan heatsink, so straight up and remove the plastic clips on the sides of the sink on the motherboard.
4. Pull the heatsink and fan on the motherboard and set it aside.
5. Lift the AMD processor motherboard and carefully remove it from the computer.
Computers & Internet Logo
I want to buy a new assembled cpu. I live in Yamunanagar Haryana (India). What are the best parts we can get in a budget of 10000-15000 INR?
Processors are already assembled from the factory, Intel, AMD, or VIA.
(VIA still make CPU's? Hmmm, have to go look) CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
Nov 17, 2012 | Computers & Internet
Will a AMD Athlon 64 processor work in a Compaq Presario SR1050NX Desktop? My old processor Died and I purchased one of these off of Ebay, now just want to make sure it will work...
No Donnie, the motherboard for the Compaq Presario SR1050NX won't support an AMD Athlon 64 processor.
The reason why is;
A) The Processor socket on the SR1050NX's motherboard is a Socket A. (Also known as Socket 462)
Hp Support > Compaq Presario SR1050NX > Specifications > Motherboard Specifications >
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00072236&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=405454
CPU = Central Processing Unit. Another term used is Microprocessor, or Processor for short.
Look to the right of the CPU heading:
Socket A (Processor socket)
This is the Socket A processor socket used on your motherboard,
http://en.wikipedia.org/wiki/Socket_A
You can click on the photo of the Socket A processor socket, to the upper Right, to enlarge.
The AMD Athlon 64 line of processors came out after the Socket A, and used the Socket 939 first.
Then on to the Socket AM2.
(Socket 940 for some models)
List of AMD Athlon 64 Microprocessors,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors
http://www.weirdstuff.com/cgi-bin/category/10201
Oct 12, 2010 | Compaq Presario SR1050NX (DW257A) PC...
processor cores?????
Yes it does matter which processor, per motherboard. This board is compatible with AMD cpu's (Central Processing Units). I recommend getting a Athlon XP 3200+ processor, although you can get faster or slower AMD processors based on how much money you want to fork out. This motherboard uses a VIA KT600 chipset, for your information.
Jan 01, 2010 | EPoX EP-8KRA2+ Motherboard
want to make a Presentation on all type of Processors
search in google.com for example "Intel Wiki"that will provide you with the most info about intel cpus and there is "AMD Wiki" that will bring up info links for amd cpus
Aug 01, 2008 | Computers & Internet
305 people viewed this tip
David Payne
David Payne
