Tip & How-To about Computers & Internet
How to Delete Protected Folders from a Memory Sticks
Folder on the removable media used both FAT32 and NTFS file systems in Windows operating system. Some of these attributes in the rule of the people (name, size, creation date, and time) can be seen, others have explicit measures to ensure Windows. Among the latter are "read only" (if set, the folder cannot be erased) and "hidden" (if set, the folder does not appear in the parent directory.) A folder is set with one of these protected attributes clear. With a few extra steps, but you can secure a folder from a memory stick.
1. Connect the memory stick for your computer. Windows will recognize it automatically and make your content accessible.
2. Click the "Start" and "run" (without quotation marks) into the search box. Click the "Run" link, type "cmd" and press Enter. A command window opens.
3. Type the following commands in the command window:
E:
cd "\ myfiles \ projects"
Replace "E:"with the drive letter for the Memory Stick and replace "\ myfiles \ projects" with the full path to the folder containing the folder you want to delete protected. Press Enter after typing each line.
4. Type the following command to remove the attributes currently prevents you from deleting the folder:
attrib -r -h folderName /e
"Folder Name" Substitute the name of the folder you want to delete. Press "Enter ".
5. Delete the folder by clicking "Start", then "Computer". Navigate to the folder you want to delete, click once and press Shift-Delete. "Windows will erase a protected folder from memory stick.
Computers & Internet Logo
Digital id gone after factory restore. I cannot forward emails with pictures.
all data is removed after a full factory restore
you might try one of these undelete programs there are many of them at either cnetdownload.com or major geeks
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media.
http://majorgeeks.com/Ultimate_Data_Recovery_d5336.html
Have you accidentally deleted important files from your hard drive, or your hard drive became corrupted, losing all or some of your important data, files, and folders?
As long as your system
May 24, 2011 | Computers & Internet
i want to format my flash disk but am told'windows cannot format' , what can i use
On a Windows XP-based computer, you cannot format a Memory Stick removable media device by using the FAT32 file system because there is no option to for FAT32 in the Format Local Disk dialog box. The only available option in the File system list in the Format Local Disk dialog box is FAT
So that you can use NTFS option to your HDD and then format the removable media device
Mar 22, 2011 | PQI 512MB Intelligent Stick USB 2.0 Flash...
my 1.5 tb mybook has been formatted to fat32, and i cant watch movies on my ps3 no more loads up files really slow even freezes. Also disappears on my laptop sometimes then reappears. But transfers and loads really slowly why?
FAT32 was the file type used for the early Windows operating systems. With the release of Windows NT and XP it switched to NTFS file system. FAT32 is still used however to transfer data between Mac and PC. The downside of FAT32 is the files read slower and file size cannot exceed 4GB. If you do not use a Mac I would suggest using the Disk Management utility in Control Panel under Computer Management to convert it to NTFS.
Mar 16, 2011 | Western Digital My Book Essential Edition...
1,090 people viewed this tip
David Payne
David Payne
