Tip & How-To about Computers & Internet
How to Clean the Computer Wires
1. Turn off all computers and unplug all cables. Remove the cable from the desktop and add them one by one. Use shelves or cabinets for computer partition if you have lots of equipment. Use cabinets with pull for easy access to the connectors on the back.
2. Use cable clips, saddles or clamps to route your cables along one wall. cluster using heat shrink cables in the same place. Also use the shrink tube as a chance to color code the cables. Label the harness with a fine tip marker.
3. Use cable turtle organizer or organizers roll equal to the length of additional cable. Tie small groups of cables together with Velcro.
4. Laying on rubber cord covers all cables running across a bridge or other area busy. Use covers to protect the people on the ground and the cables.
5. Take advantage of flexible hoses, if you need a plastic tube to protect the cable from wear and tear. Use a cable career as a wall-line to the wires of the line of fire to hide.
Computers & Internet Logo
i got this computer from my sons coach but it has a password on it how do i get pass that
Is it power on (BIOS password or Windows Password?
Clearing Forgotten BIOS Passwords (from Owners Manual Page 109)
CAUTION: To guard against electrical shock, always unplug your computer from
the electrical outlet before opening the cover.
Shut down the computer through the
Start
menu (see page 27).
NOTICE:
To disconnect a network cable, first unplug the cable from your computer and then
unplug it from the network wall jack.
Turn off any attached devices and disconnect them from their electrical outlets.
Disconnect the computer power cable from the wall outlet, and then press the power
button to ground the system board.
Remove the computer cover (see page 74).
5
Locate the 3-pin password jumper (see page 77) on the system board, and then attach
the jumper to both pins.
When you receive your computer, the jumper is attached to only one pin.
6
Replace the computer cover (see page 99).
NOTICE:
To connect a network cable, first plug the cable into the network wall jack and then
plug it into the computer.
7
Connect your computer and devices to electrical outlets, and then turn them on.
8
If you are prompted to press <F1> to continue, press <F1>.
9
After the Microsoft Windows desktop appears on your computer, shut down the
Start
menu (see page 27).
NOTICE:
10
11
12
13
Remove the password jumper.
Attach the jumper to only one pin so that you do not lose it.
Aug 05, 2014 | Dell Dimension 4600 PC Desktop
i reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire l100....thanks!
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    power light stays on without booting up. Unplugged the power cord and replugged, power light green and cannot responsive to on / off
    its lookin like Moistre problem, If you Know Lil bit of computer hardware. then unplug the Power Cord, Remove the CPU cabinet cover. locate the RAM
    Remove the RAM by sliding back the side locks and insert it BACK. Put the cabinet cover etc and power it ON. If same problem persists Remove the Graphic Card(if you Have). if graphics is Onboard
    then the Problem with the Onboard graphics. send it to service center or buy New one.(You can try also Deassembling all Parts like processor, ram, cables etc) best of luck
    Jan 28, 2011 | Dell Precision Workstation 670 PC Desktop
    How do I remove my CD drive and replace it with a new DVD drive?
    u just have to open ur cpu cabinet rom both sides and then unplug the power cable and sata or pata cable from cd drive unscrew it.then push towards out of the cpu by applying pressure from inside.
    now take ur Dvd drive push it inside the cpu from the front,adjust it and screw it.Connect the power cable and see that whether it is a pata or sata cable writer connect to proper port then close cabinet.Now u hv successfully fixed new drive.
    Mar 30, 2010 | Dell Dimension 2350 PC Desktop
    227 people viewed this tip
    David Payne
    David Payne
