Tip & How-To about Computers & Internet
How to back up window 7
Back up your important files and programs absolutely necessity for time. Fortunately, Windows 7 has a built in your favor in the implementation of data backup and recovery procedure for your computer support. Use Backup and Restore Backup Windows 7 and all data stored on the hard disk. Although the Windows utility does not have many extra features such as third-party tools, is more suitable for the backup process and cost you a penny.
1. Connect the USB cable from the external HD into a USB port on your computer. Connect the "Startup" window that opens.
2. Click Start, click Control Panel. Click "System and Maintenance, click Backup and Restore" button.
3. Click on "Configure backups to backup and restore window that opens. Click on" External Hard Drive "in the destination window and click Next. This means that the hard drive as the location of backup files.
4. Click the "Let me choose" option to a dialog to open files on your computer. Click to select Include system image units. "This option ensures that the backup is a copy of Windows 7 operating system, so belong to reformat or hard disk crash can be recovered.
5. Click "Next" and click "Save Settings and Run-up" on the confirmation window to start creating a backup of your operating system Windows 7. Do not get your hard disk to the process.
Computers & Internet Logo
What are the steps for System restore in windows 7.
System Restoring Windows 7
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
Aug 08, 2011 | Microsoft Windows 7 Ultimate for PC
i was using windows vista home basic before but that was slow then i changed it to windows 7 ultimate now but i think i make a mistake so i would like to get my vista back how can i get it because i didnt create a recovery disc
try to restore your system try this steps and make sure you will back up this time your important files.. 1. click start or the circle windows logo in your task bar. 2. click all programs and then click accessories. 3. click system tools then after that click system restore then. 4 when you in the system restore then click next and chose the restoration point where you are still using windows vista..If this wont work re install your windows vista using your installation disc but make sure you back up the important files first...Hope it will help you
Jul 13, 2011 | Computers & Internet
startup programs sometimes late
The reason for start up programs running late is because there are more programs installed in the computer and it takes lots of time to get these programs to run during startup. Some of these programs are not too useful but will always delay a computer startup. More and more people are becoming aware of how important it is to take control of the "autorun" programs on their PCs. In case you didn't know, an autorun or startup program will launch automatically when Windows starts. Quite often, it's a useful program and you can find it's icon in the system tray. However, sometimes an autorun is not that useful. You may not know it's installed because it's hidden or you've forgotten you installed it. When that happens, these not so useful programs are taking up processor cycles and eating up system memory. Your PC gets slower as more hidden programs are launched as an autorun. Fortunately, there are several ways to take control of the autorun programs. Windows has a utility built in called "msconfig", and there are also quite a few third party autorun apps such as this one: Autoruns by Sysinternals. Autoruns is offered for download as a ZIP file. To install it, extract the ZIP file to a folder somewhere on your PC. You'll see the following four files in the folder. lonerangerx7.png
Double click the "autoruns.exe" file to launch the program. Here's a peek at Autoruns in action. lonerangerx7_0.png
If you find a program you aren't familiar with, you can right click on it and choose the "Search Online" task. That will open your web browser and send you to the search results for the file or process that you have highlighted. In order to stop a program from running at startup, you can remove the little check-mark beside it. The interface may look confusing at first, but if you run into any problems, you can always consult the built in help from the top menu. I hope this explanation helps in solving your problems
Dec 15, 2010 | Computers & Internet
236 people viewed this tip
David Payne
David Payne
