Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Join various MTS files-Import and Convert different AVCHD MTS files to ProRes for FCP
Join/Convert Panasonic/Canon/Sony/JVC various MTS to ProRes for FCP without rendering
Edit all MTS Videos on FCP-Merge/Convert HD Camcorder MTS files to FCP ProRes on Mac
As the reason of recent activities, I have a lot of different .mts Videos for Editing. These .mts video most are from camera, camcorder, like Sony CX700, XR520,Sony Nex-5, Canon HF G10, HG20,HF100,Panasonic HDC-TM90,SD700,Lumix GH2.etc.Some .mts videos can be directly into FCP editing, some not. So in order to Edit all MTS Videos on FCP, I need a converter to Import and Convert various MTS. But separating each video conversion is a lot of trouble, so I will need to merge those mts videos into one and convert. Through Google search, I found Aunsoft Final Mate for Mac is the recommended MTS Joiner/Converter- can join and convert mts to FCP for editing on Mac. Then I download and try it. And I had successfully converted a total of 15.8G mts files to MOV and edit on FCP, I choose the Apple ProRes MOV as output format, so that I can import prores mov to fcp without rendering.
Following is the experience of using Final Mate for Mac to Merge and Convert Panasonic/Canon/Sony/JVC various AVCHD MTS files to ProRes 422 for editing on FCP.
Step 1 : Import various mts Files from Computer to Final Mate for Mac.
Click "Add" to browse computer and select a folder where video files are saved, then click "OK" to display all video files including various MTS files in Resource Tab.
Step 2. Create a Movie for Combining/Converting AVCHD MTS files.
Soon after the mts files are imported, you need to create a movie for conversion. There are two ways for you to create a Movie for converting imported various MTS files.
- The easiest one is dragging and dropping displayed various MTS files from Resource Tab to a single Movie.
- Another way is clicking the drop-down button of "Add Movie" icon and choose "For Conversion" to create a blank movie. And then drag and drop the video clips from Resource Tab to the blank movie in Movies Tab. In this way, all video clips will be merged as one single movie for conversion.
Step 3. Export ProRes video file for Final Cut Studio.
Click the Export and choose Final Cut Pro > Apple ProRes 422 HQ (*.mov) to output format for editing in Final Cut Pro. Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Tips: You are free to set/adjust output ProRes MOV files parameters (Bit rate - high quality, Frame rate - 30, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality.
Step 4. Click OK to start Joining and Converting different AVCHD MTS to ProRes.
Click OK button, the software will automatic Join and Convert the various mts files into one big files.
When the conversion is finished, you can get big files for importing and editing on Final Cut Pro without rendering.
Tips: If you are using Final Cut Pro 5 or lower version, ProRes is not the best format for you. However, you can choose QuickTime Movie Format > Apple InterMediate Codec(AIC) as output format for editing on Mac.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Convert AVCHD Files to Apple ProRes 422 for FCP with Best Camcorder Software for Mac Do you have problems of importing AVCHD 1080/60p, 1080/50p, 1080/60i MTS or M2TS files to Final Cut Pro and want to find camcorder software on Mac OS X to Transcode AVCHD files to Apple ProRes Codec for editing in FCP without rendering? As the best camcorder software on Mac OS X for Sony, Panasonic, Canon, JVC camcorders, Aunsoft Final Mate for Mac is featured with one most important feature for Mac users-help Convert AVCHD video footage to Final Cut Pro ProRes formats including Apple ProRes 422 Codec, Apple ProRes 422 HQ Codec, Apple ProRes 422 LT, Apple ProRes 422 Proxy, Apple ProRes 4444 Codec. With Final Mate for Mac as the default camcorder software on Mac, you can choose preferable format for editing on Final Cut Pro without rendering. Final Mate for Mac also support converting AVCHD files to Apple Intermediate Codec(AIC)for editing in Final Cut Express or iMovie. The guide will share with you a easy and fast method of Converting AVCHD files to Apple ProRes 422 with featured software for camcorder on Mac. 1.Run AVCHD to Apple ProRes Converter for Mac and add AVCHD files. Launch Aunsoft Final Mate for Mac and add AVCHD files to the program by clicking on "Add" button to browser AVCHD file path on your local Mac computer. Then all AVCHD MTS/M2TS clips will show in Resource Tab of Final Mate for Mac. 2.Join AVCHD files and choose Apple ProRes 422 as output option. Directly drag and drop AVCHD files from Resource Tab to Movies Tab or Timeline to create a new movie and join AVCHD files into one for converting to Apple ProRes 422 Codec. There will be a pop-out window during the process shown as following: Please choose "Create A Single Movie" to merge all AVCHD video footage into one movie. 3. Start converting AVCHD to Apple ProRes 422 Click on Export button and follow Export into Editor > Final Cut Pro > Apple ProRes 422 HQ(*.mov) format to choose your output format for converting AVCHD to FCP supported format. Confirm your settings and click ok to starting conversion. Minutes later, you can access combined Apple ProRes 422 MOV movie by clicking on "Browse for Export Path". Now you are able to edit AVCHD files on FCP without rendering with the help of Final Mate for Mac as the best camcorder software on Mac OS X.. Tip: If you use iMovie or Final Cut Express for AVCHD editing, you may be interested to know how to Convert AVCHD files to Apple Intermediate Codec for iMovie/FCE.
Jun 28, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Transfer/Convert Sony HDR-CX150 AVCHD MTS Movie to Apple ProRes for Final Cut Pro on Mac Sony Handycam HDR-CX150 is listed as one of the best home movie camcorders by Lori Grunin, senior editor from CNET.com. However, people are not giving a high credit for this camcorder. Just like Lori puts it in her review for Sony CX150: "Its small size and attractive price might draw you to the Sony Handycam HDR-CX150, but this bare-bones camcorder just barely delivers on the promise of HD quality." For many Mac users, editing AVCHD footage on Final Cut Pro is not very pleasant with many problems & frustration, though Final Cut Pro 6.0.1 claims to give native AVCHD support. In the guide, I will share with you how to batch convert AVCHD MTS/M2TS videos to Apple ProRes format for smooth editing in FCP without rendering. Featured Camcorder Software for Mac OS X - Aunsoft Final Mate for Mac Aunsoft Final Mate for Mac, a useful camcorder software program for Mac OS X, make it easy to capture AVCHD videos from camcorder, edit in Timeline for joining/cutting/splitting MTS/M2TS files, AVCHD lossless output for HD memories on TV, export to Final Cut or iMovie with provided Apple ProRes codecs & Apple Intermediate Codec, or share the fun online. Highlights of Aunsoft Final Mate for Mac - Full HD support for AVCHD, TOD, MOD camcorders - Support merging/spitting AVCHD without conversion - Convert camcorder footage to Apple ProRes, AIC, Avid DNxHD Codec How to Transfer/Convert Sony CX150 AVCHD to Apple ProRes on Mac OS X Learn how to convert AVCHD MTS or M2TS files to Apple ProRes codec via Aunsoft Final Mate for Mac with Sony CX150 as an example in the guide. Step 1. Import AVCHD MTS from CX150 to program. There are two ways to import AVCHD videos to Aunsoft Final Mate for Mac. - Capture AVCHD videos from CX150 camcorder If you choose to import videos directly from camcorder to the program, first of all, please turn on Sony CX150 and connect it to your Mac via USB cable. Launch Aunsoft Final Mate for Mac and follow camcorder wizard to import videos to the program. Imported Sony mts files will be shown on Camcorder Tab of the program. - Import AVCHD videos from computer If you have already transferred video footage from camcorder to your computer, you can browse the file path through "Add" icon. Then all AVCHD videos in the folder will show in Resource Tab of Aunsoft Final Mate for Mac. Step 2. Join MTS clips into one for conversion. In order to join AVCHD mts clips of Sony CX150 into a complete movie, all you have to do is to drag & drop AVCHD videos from Camcorder Tab or Resource Tab to Movies Tab. During the process, a pop-out window will show as below: Choose "Create A Single Movie" to merge Sony CX160 MTS clips into one movie. Step 3. Convert AVCHD Movie to Apple ProRes. Click on Export and then choose "Export into Editor". In the panel, please follow Final Cut Pro > Apple ProRes 422 to confirm your output format to Convert Sony CX160V AVCHD Movie to FCP ProRes format. Step 4. Transfer output ProRes MOV to Final Cut Pro. Import exported ProRes MOV movie from Aunsoft Final Mate for Mac to Final Cut Pro and start your smooth editing without rendering. If you love video making on Mac OSX, Aunsoft Final Mate is highly recommended as a practical Camcorder Software on Mac. Tip: You may also want to know how to convert AVCHD to Apple Intermediate Codec for iMovie/FCE or merge AVCHD without re-encoding to preserve original quality. Tags: best camcorder software for Mac OS X, Convert MTS/M2TS to Apple ProRes, AVCHD Joiner/Converter on Mac, Convert AVCHD to Apple ProRes 422 HQ
1,171 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
