Tip & How-To about Televison & Video
How to Program the Sony RM-Y913 Remote Control
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press the CODE SET button.
  3. Press the FUNCTION button for the desired component.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the component POWER button to verify operation.
Follow this link in order to get your programming codes for your specific devices related to the Sony RM-Y913 Remote Control:
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMY913
Televison & Video Logo
What are the remote codes for Sony RM-EZ4 / Haier TV, Comcast Xfinity cable box?
  2. Press the SET button.
  3. On the remote control, press the appropriate component button.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  8. Press the POWER button to verify operation.
Comcast offers several remote controls. The type of remote you get depends on the device you're using. Some Comcast remote controls are multi-device or universal remotes, while others only control the set top box and TV.
May 06, 2012 | Sony RM-EZ4 Universal Remote Control
URC-R6 Remote Code Entry
Anyone know the code for a Sony DAV-DX375 home-theater system?
Jul 14, 2010 | Televison & Video
How do I program my vcr.dvd player and my digital device box. I do not have my users manual.
  3. Press the appropriate FUNCTION button for the type of component being programmed.
  6. Press the ENTER button.
  8. Press the appropriate component POWER button to verify operation.
Feb 27, 2011 | Sony RM-Y195 Remote Control
I lost the papers that tells me how to set it up sony rm-v210 remote control
Here ya go. Heres some brief instructions and a link to sony for the codes and full instructions
  2. On the remote control, press and hold the SET button until the SET indicator lights up.
  3. Press the appropriate component select button for the component being set up.
  7. Point the remote control at the component and press the POWER button.
NOTES:
  • If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • The operation of a combination deck of any kind is not guaranteed.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
go here for more information http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV210
Oct 17, 2010 | Sony RMV210 Remote Control
2,990 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
