Tip & How-To about Computers & Internet
How to force an Apple computer to eject a stuck CD or DVD
Most of us have experienced it at least one, and if it hasn't happened to you yet, it's just a matter of time: a damaged CD, a failed DVD burn, or an unrecognized disc just won't eject from the Apple computer's disc drive. Here's a simple solution to force that stubborn CD out. Note: this tip requires a restart, so be sure to save any open files before proceeding.
(1) Save any open files and documents and quit all open programs.
(2) Click on the Apple icon in the top-right corner of the screen and select "Restart."
(3) Click the "Restart" button on the message box that pops up.
(4) As soon as the screen turns black, before the computer begins rebooting, click and hold down the mouse button. See step 4(a) for more details about this step.
(4a) If you have an older model trackpad, click and hold the trackpad button. If you have the new, button-less trackpad, click and hold down the trackpad itself. If you have a two-button mouse, click and hold down the left mouse button. If you have a wireless Bluetooth mouse, click and hold the left mouse button (though you may not have success with the MagicMouse; use a wired USB mouse if you have one available).
(5) Keep the mouse button held down until the CD/DVD media is auto-ejected from the drive.
If the CD still remains stuck in the drive, there is a more serious problem at work, and the assistance of an authorized Apple technician will likely be required.
Computers & Internet Logo
2002 chev pu heater won't change to a/c -blows hot air all the time
The first thing to do here is have the AC system checked to make sure your refrigerant hasn't leaked out due to a failed seal or damaged condenser core.
Jun 11, 2012 | Cars & Trucks
timer won't advance on autosense,seems to work normally otherwise. timer advances fine on all other settings. was thinking it was the cycling thermostat, but the blower seems to be cycling. puzzled
when on auto the heat comes on and then shuts off and then the timer advances,when the heat comes back on the timer stops advancing,when on time dry the timer will advance no matter what's happening with the heat.next time send the brand name and model number so i can help you better,if it's gas you could have bad gas coils,you'll have heat for like the first 15 to 30 minutes then when the coils get hot they fail and no heat until they cool down,also if the vent line and the duct that the lint filter goes into hasn't been cleaned out the heat will shut down and if that happens the timer isn't gonna move.check that out and let me know what you find and send the brand and model number.
Sep 24, 2011 | Roper Dryers
I have burnt photos onto a Dvd-R but my sony dvd player wont play. it plays other Dvd-R. Can you advise. I put disc back and did 'Close Session
Hi rod4926
You need to retry on a DVD-RW and see what's happening . Probably the DVD hasn't been properly finalized . Check your software options .
Best regards ,
fanaudi .
Aug 29, 2011 | Sony Computers & Internet
Put in a cd in the ps 3 with a crack inside it did not play but now I can play anything cannot see movies
Hi!
Wow, that stinks! A foreign object broke off BD and is affecting your BD drive or the damaged BD itself damaged the drive. Hopefully it hasn't damaged it permanently. Repair center time. Good luck.
May 10, 2011 | Sony Video Game Consoles & Games
I have made several attempts to play a disc on my JVC TH-V70. IT reads 'reading' on the dvd unit then after a few second the disc ejects. Why is this happening?
Hi Adrienne - If it only happens to the one DVD it is most likely a problem with the DVD being damaged or dirty.
If it's happening with all your DVDs your player laser lens is probably dirty or it might be damaged. If no discs are being read get yourself a CD/DVD cleaning disc and run it a couple of times (following the directions). Of this doesn't work you will have to decide if the player is worth the price of a repair (unless it's still under warranty). Most aren't as you can buy decent players for less than $50. Any repair will cost at least that.
If it is the one disc I suggest you take a clean soft cloth and wet it slightly with plain water and the give it a few strokes across the disc (not in circles), let it try dry for a few minutes and try it again. Also examine the disc (bottom) for any obvious scratches or stuck on gunk.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 28, 2011 | JVC TH-V70 System
394 people viewed this tip
David Payne
David Payne
