Tip & How-To about Computers & Internet
How to create a password recovery disk
How to create a password reset disk
To create a password reset disk for your local user account, use one of the following methods.
Requirements
The following methods require one blank, formatted floppy disk.
Use a computer administrator account
If you logged on to the computer by using an administrator account, follow these steps to create a password reset disk for a user account:
  1. Click Start, and then click Control Panel.
  2. In Control Panel, click User Accounts.
  3. In the User Accounts pane, click the account that you want to work with.
  4. Under Related Tasks, click Prevent a forgotten password to start the Forgotten Password Wizard, and then click Next.
  5. Insert a blank, formatted disk into drive A, and then click Next.
  6. In the Current user account password box, type the password for the user account that you chose in step 3, and then click Next.
    Note If the user account does not have a password, do not type a password in the Current user account password box.
    The Forgotten Password Wizard creates the disk.
  7. When the Progress bar reaches 100% complete, click Next, and then click Finish.
  8. Remove and then label the password reset disk. Store the disk in a safe place.
Use a limited account
If you logged on to the computer by using a limited account, follow these steps to create a password reset disk for your user account:
  2. Under Pick a category, click User Accounts.
  3. Under Related Tasks, click Prevent a forgotten password to start the Forgotten Password Wizard.
  4. Click Next.
  6. In the Current user account password box, type your password, and then click Next.
    Note If your user account does not have a password, do not type a password in the Current user account password box.
How to log on to the computer by using a password reset disk
If you forget your password, you can log on to the computer by using a new password that you create by using the Password Reset Wizard and your password reset disk. To do this, follow these steps:
  1. On the Windows XP logon screen, click the user name that you want to use. The Type your password box appears. Press ENTER or click the right-arrow button. You receive the following error message: Did you forget your password?
    You can click the "?" button to see your password hint.
    Or you can use your password reset disk.
    Please type your password again.
    Be sure to use the correct uppercase and lowercase letters.
  2. Click use your password reset disk. The Password Reset Wizard starts. The Password Reset Wizard permits you to create a new password for your user account.
  3. Click Next.
  4. Insert the password reset disk into drive A, and then click Next.
  5. Type a new password in the Type a new password box.
  6. Type the same password in the Type the password again to confirm box.
  7. In the Type a new password hint box, type a hint to remind you of your password if you forget the new password.
    Note This hint is visible to anyone who tries to log on to the computer by using your user account.
  8. Click Next, and then click Finish. The Password Reset Wizard quits, and you return to the Windows XP logon screen.
    Note The password reset disk is automatically updated with the new password information. You do not have to create a new password reset disk.
  9. Type your new password in the Type your password box, and then click the right-arrow button to log on to the computer.
Troubleshooting
  • The password reset disk cannot be used to reset the password on another computer.
    The password reset disk that you create can only be used with the computer it was created on. For example, if you have two Windows XP-based computers that have the same user names and passwords, a password reset disk that you create on the first computer cannot be used to reset the password on the second computer.
  • The password reset disk contains sensitive information.
    Other users may be able to use the password reset disk to gain access to your computer. For this reason, store this disk in a safe and secure location.
Computers & Internet Logo
Create a Password Reset Disk
If you’re running Windows XP Professional as a local user in a workgroup environment, you can create a password reset disk to log onto your computer when you forget your password. To create the disk:
Click Start, click Control Panel, and then click User Accounts.
Click your account name.
Under Related Tasks, click Prevent a forgotten password.
Follow the directions in the Forgotten Password Wizard to create a password reset disk.
Store the disk in a secure location, because anyone using it can access your local user account
Oct 20, 2008 | Computers & Internet
How to enable Windows 7 administrator account and reset lost Win 7 admin password There are two parts for your Windows 7: * Enable Windows 7 administrator account * Reset lost Win 7 admin password With 240 million licenses sold out in one year, Windows 7 has been proved to be a successful product of Microsoft. Compared with its previous versions like Windows XP, it has many improved features. The built-in administrator account is one of the features. In Windows XP, there is a default administrator account after installation. But the built-in administrator account is disabled by default in Windows 7. To enable Windows 7 administrator account and assign a password to it, you can achieve it in 2 methods. Part I: Enable Windows 7 administrator account Method 1: Use Command Prompt The easiest way to enable the Windows 7 built-in administrator account is to use the Command Prompt. 1. Click Start and type CMD in the search box. Right-click CMD and select Run as Administrator. 2. Click Yes when prompted to allow the Command Processor to run. And then the command prompt will appear. 3. Type net user in the command prompt window, and then hit Enter. All the Windows account user names will be listed. You'll also see the Administrator account, but now it is not enabled. 4. Type net user administrator /active:yes and hit Enter to enable Windows 7 admin account. Now the Windows 7 administrator account is created. To create the Windows 7 administrator password, you can follow the below steps: 1. Switch to log on Windows 7 with the administrator account. 2. Click Start, Control Panel, User Accounts and Family Safety and User Accounts in order. You'll enter the screen where you can make changes for your account. 3. Click Create a password for your account on the screen. 4. In the coming screen, type and confirm your Win 7 admin password. 5. Enter password hint and click Create Password. Now your Windows 7 admin password is successfully created. Method 2: Use Local Users and Groups 1. Click Start and type lusrmgr.msc in the search box, and then hit Enter. The Local Users and Groups screen will come up. 2. Double-click the Users folder. And all the Windows 7 account will be displayed for you. 3. Right-click the Administrator account and select Properties. 4. Uncheck the "Account is disabled" check-box and click OK on the administrator properties screen. Now Win 7 admin account is enabled. To set a password for the enabled Windows 7 administrator account, follow the steps as below: 1. Right-click the Administrator account and select Set Password. 2. Click Proceed to go on your operation 3. Type and confirm your new Win 7 admin password and click Ok 4. Close the Local Users and Groups screen. Now the Windows 7 administrator password is assigned to your Windows 7 admin account. Part II: Reset lost Win 7 admin password Windows 7 administrator password reset Tips: Note 1. Please remember to create a Windows 7 password reset disk after assigning Windows administrator password. It allows you to change your forgotten Win 7 admin password when you are locked out of Windows. Note 2. If you forgot to create the password reset disk, you can choose to use Windows Password Breaker to help create a Windows 7 password reset disk rather than reinstalling the system. Now follow the steps to create the disk to reset Windows 7 password. step 1. Download and install Windows Password Breaker. step 2. Run the program and burn a Windows password reset disk. Step 3. Reset Windows 7 administrator password with the disk. It is an easy and safe way for Windows 7 admin password reset.
Nov 02, 2010 | Computers & Internet
365 people viewed this tip
David Payne
David Payne
