Tip & How-To about Washing Machines
Washing Machine Fault Codes These fault codes are written for washing machine repairers and not for the general public and they assume a certain level of competence on the part of the user in diagnostic routines. I have added some notes to try to assist you in determining the nature of the fault you have but, you will still need to investigate each failure on its own merits. Please check that any washing machine spares recommended are suitable for use on your particular model and serial number. Please, don't guess or assume as spares can be altered on a production run with the same model number having several different alternative components used. E1 Not filling in allocated time This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed. We do list the generic water inlet valves for Samsung washing machines in this section and, if you're clever you can use one of those by altering the connections but, if you need the genuine one specific to your model please contact us. E2 Pump won't empty - not draining As usual with these error codes for not draining the first thing to do is check the pump filter. When replacing the drain pump there are two basic options, the genuine one from your manufacturer or the cheap version which is essentially the same pump. Also see below about detergent use as it applies to drain errors as well as overfill error codes. E3 Overflow - overfilling with water This fault code tells you that the washing machine has detected an overfill situation and, usually, they will stop and drain for safety then report the error code above. This error can be caused by poor quality detergent or overdosing detergent both leading to excessive foam. This foam traps air in the pressure sensor hose and falsifies the error of an overfill. If this is the case, if you leave the machine for an hour or so and try it again it should then be clear but, whatever you do when you try it again do not put more detergent in the machine. If this solves it, adjust the detergent quantity or switch to a better quality detergent to prevent it happening again. E4 Out Of Balance (OOB) detected This is basically an imbalanced wash load detected that the machine has failed to sort out on its own and therefore couldn't spin to the full speed. Just sort the load and try it again. E5 Water temp rising or falling too quickly Normally an NTC temperature sensor or wiring to the sensor that's faulty. E6 Water temp rising or falling too quickly As above. E7 Pressure switch The error code is telling you that there is an error or fault somewhere in the pressure switch circuit, this could be the switch itself, the wiring or the main control module. E8 Temp too high on low temp washes Normally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number. E9 Water leak, Water level has reduced Basically this fault code means that the water level has dropped while the machine has been running so, it's either a leak, faulty pressure sensor, wiring, water escaping to the drain or the control PCB. EA Motor tacho generator error Self explanatory fault code. Most manufacturers do not supply parts for their motors, only full motors and they can be model specific. EB Motor triac error As above. EC Thermistor A thermistor is a type of resistor whose resistance varies significantly with temperature, more so than in standard resistors. The word is a portmanteau of thermal and resistor. Thermistors are widely used as inrush current limiters, temperature sensors, self-resetting over-current protectors, and self-regulating heating elements. Thermistors differ from resistance temperature detectors (RTD) in that the material used in a thermistor is generally a ceramic or polymer, while RTDs use pure metals. The temperature response is also different; RTDs are useful over larger temperature ranges, while thermistors typically achieve a higher precision within a limited temperature range [usually 90 °C to 130 °C]. As fault code E8 ED Door Open Close the door and restart the program! If that doesn't cure the problem it will most likely mean that the door lock is faulty and there's two commonly used on Samsung washing machines, this one and this one
Washing Machines Logo
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    when I on the machine LG WF-F5700PCX ,all the lights are blinking. water is not flowing in.
    Washing machine all the lights flashing, error codes on ...
    www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
    Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
    Washing machine lights flashing - White Goods Help
    www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
    Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
    Flashing Lights on Washing Machine How to Repair ...
    ? 8:05
    https://www.youtube.com/watch?v=P6WZNLO6wE4
    Oct 22, 2014 - Uploaded by how-2-repair.com
    Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
    Indesit Washing Machine Repair: Flickering Or Flashing Lights
    ? 4:36
    https://www.youtube.com/watch?v=S1L2N7srXKs
    Mar 27, 2014 - Uploaded by DextersLab2013
    Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
    Jan 11, 2016 | Washing Machines
    Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
    Whirlpool Calypso Washing Machine diagnostics & Error ...
    applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
    Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
    Washing Machine Fault Codes « Tips, Tricks & Recipes
    www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
    Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
    [PDF]Fault Code Bible v1.2.pdf - ResearchGate
    Dec 02, 2015 | Washing Machines
    The error code H 01 in Shows my washing machine(panasonic na-f70gs)
    http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
    H01
    Pressure sensor or level switch detected as out of range
    • Check wiring to level sensor
    • Check pressure switch is not defective
    • Replace pressure sensor
    • Replace main power PCB
    Apr 06, 2015 | Washing Machines
    1,153 people viewed this tip
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
