Tip & How-To about Televison & Video
Digital Noise Filter
How to remove Digital Noise Filter on Samsung LCD TV.
1. Push menu button on remocon or on side of TV set,
2. Choose " Setup --> Plug an Play
3. Insert pin combinations : 0-0-0-0 or your pin if you have change the pin.
4. Follow instruction until shown "Home Use" and "Store Demo".
5. Choose Home use.
Or use a simple methode by press vol up than menu for 3~5 second. It will change to home use.
Televison & Video Logo
DIGITAL NOISE FILTER PROMLEM IN LA32C450E1
hello,
Digital noise problem on samsung LA32c450 because of Store Demo setting.
Enter to menu, choose setup, plug and play, choose home use.
read my tips here .
good luck.
Jun 24, 2011 | Televison & Video
How to remove Digital noise filter from my samsung lc450 lcd tv
hello, to remove that problem you can use this method;
1. Enter to menu - plug and play - than follow instructions 'til home use and store demo appear.
select home use. or,
2. Push volume button on side of tv until volume bar appear, than push menu button 3-5 second.
good luck.
Mar 27, 2011 | Samsung LE40R74BDX 40 in. LCD Television
i get the "Digital noise
Try this method :
1. Menu, select setup
2. Plug and Play
3. Enter pass code by entering 4 digit number (0-0-0-0)
4. Select language
5. Switch to Home Use
6. Follow the instructions.
Good luck.
Mar 07, 2011 | Samsung LE40R74BDX 40 in. LCD Television
How to turn off display on bottom
Hi, try this :
1. Switch on your TV set
2. Open menu, choose setup - plug and play
3. select language
4. enter pass code (0-0-0-0)
5. follow instruction until " home use and store demo" appear.
6. Choose "home use".
7. Follow the instruction agian untill plug and play setting finished.
Feb 18, 2011 | Samsung UN40C5000 TV
3,114 people viewed this tip
Top Televison & Video Experts
