Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Flawlessly solve questions-Canon HG20 MTS to iMovie 9 with retain best quality
Flawlessly 1080/60i MOV for iMovie-Converting Canon HG20 MTS files to AIC MOV for iMovie
I have a Canon HG 20 with an internal 60GB hard drive. I am using the Mac OS X 10.6 Snow Leopard and iMovie 09. The apple website says that this camera is compatible with iMovie and even sells it on it's website. When I open iMovie and import the .mts files to iMovie, it prompt an error. After google search, found if I want to edit Canon HG20 1080/60i .mts video with high quality for iMovie 9 on Mac, must to convert Canon HG20 1080/60i .mts files to MOV for iMovie 9 before editing.
And as we konw, Apple Intermediate codec is one of the apple built-in codecs, while others could be Apple DV/DVCPRO - NTSC, DVCPRO50 - NTSC.So convert hg20 mts to aic mov is the best choose. Therefore i need mts to aic converter. Aunsoft Final Mate for Mac is the recommended camcorder software to convert AVCHD to apple compatible formats.
Here is the step-by-step guide to quickly convert Canon HG20 MTS to Apple Intermediate Codec 1080/60i (*.mov) with highest quality for editing in iMovie 9 on Mac.
Step 1. Directly download 24Mbps .mts files from Canon VIXIA HG20 to Aunsoft Final Mate for Mac.
Turn on Canon HG20 camcorder and connect it to computer via USB cable, then launch Aunsoft Final Mate for Mac from Application folder. With built-in wizard, you can easily to capture Full HD .mts files from Canon HG20 camcorder to the program. Select "Import" instead of Backup to quickly capture videos from camcorder. You can find imported videos under "Camcorder Tab" in the main interface of Final Mate for Mac.
Step 2. Create a Movie for Converting Canon VIXIA HG20 MTS files to AIC MOV.
Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created.
Step 3. Export AIC MOV video file.
Click the Export button and choose iMovie and Final Cut Express > Apple Intermediate Codec (AIC) (*.mov) to choose export format for further editing in iMovie. In this way, all video clips will be merged as one single movie for convert to iMovie.
Tips: You are free to set/adjust output MOV files parameters (Bit rate - high quailty, Frame rate - 60, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. With this set you can get a Flawlessly 1080/60i MOV for iMovie.
Step 4. Click OK to start converting.
Click "OK" to start converting Canon HG20 MTS files to AIC MOV for iMovie .When the conversion is finished, you can import converted mov to iMovie without rendering and edit high quality videos from Canon Vixia HG20 24Mbps mts on iMovie Mac.
Tips: The Canon VIXIA HG20 boasts 1920 x 1080 Full HD, and has a CODEC capable of recording 24Mbps -- the highest AVCHD bitrate --through Canon's own Full HD CMOS Image Sensor and advanced DIGIC DV II image processor. Final Mate for Mac also can lossless split/cut and join/merge Canon HG20 Full HD MTS on Mac with no compression.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Capture video from Canon Vixia stopped working with iMovie
Video files come from Canon Vixia hg20 are in AVCHD format and this is a format which is difficult to be imported and edited by FCP and iMovie. So you have to convert AVCHD files to other easily edited video format, like FCP and iMovie preferred MOV format.
As for AVCHD Converter, have a try Aunsoft MTS Converter for Mac which is is a powerful video converter, player, editor for Mac and Windows. It can play many various movie files; it can encode movies to many formats, including iPod; it can cut, trim and join movies.
You can use this program to open and play most movie formats transport streams; edit them with crop and Trim;export them to QuickTime, AVI, DV and MPEG-4 files with more than professional quality, so you can easily import them in a DVD authoring tool, and use them with many other applications or devices.
http://www.aunsoft.com/mts-converter-mac/
May 10, 2010 | Canon VIXIA HG20 DVD Blu-ray Camcorder
Convert Sony TX100V 1080/60p MTS to AIC MOV for iMovie 11 and keep the raw quailty The Sony DSC-TX100V is on the iMovie '11 compatibility list, But it's a AVCHD 1080/60p camera -- iMovie '11 supports only 30fps! The Sony DSC-TX100V another option for 1920 x 1080/60i which equates to 60 interlaced fields per second, but the video quality of 60i recording mode is not better than 60p mode, so personally i prefer to choose 1080/60p for recording mts footage.So if I want to edit Sony DSC-TX100V 1080/60p .mts video with 60fps high quality for iMovie 11 on Mac, must to convert Sony DSC-TX100V 1080/60p .mts files to iMovie 11 before editing. After google search , I need convert my Sony DSC-TX100V 1080/60p .mts to Apple Intermediate Codec MOV for iMovie 11 with keep the raw quailty, I found Final Mate for Mac is the recommended can convert Sony DSC-TX100V 1080/60p MTS to 1080/60p AIC MOV for editing on Mac. Then I download and try it. And I had succeed with the Apple Intermediate Codec at 1920x1080 60fps editing for iMovie 11 and i'm very satisfactied with the output quality after uploading the videos on Youtube. Here is the step-by-step guide to quickly convert Sony DSC-TX100V 1080/60p MTS to AIC 1080/60p (*.mov) for editing in iMovie 11 on Mac. Step 1. Directly download 60fps .mts files from Sony DSC-TX100V to Aunsoft Final Mate for Mac. Connect Sony DSC-TX100V to PC via USB cable. You will face the pop-up message asking you to use camcorder wizard or not. If you do not get the message, just click the Wizard button. Click Yes and follow the wizard to download/import 1080p files to the program. Step 2. Create a Movie for Converting Sony DSC-TX100V 1080/60p MTS files to AIC 1080/60p MOV. Method 1): Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created. Method 2): Click downlist of Add button and select for conversion. A blank movie is created. Then drag and drop your Sony DSC-TX100V 60fps .mts files to such a movie for merging together and making a conversion. Step 3. Export AIC MOV video file. Click the Export button and choose "Export into Editor". Follow iMovie and Final Cut Express > Apple Intermediate Codec (AIC) (*.mov) to choose export format for further editing in iMovie. In this way, all video clips will be merged as one single movie for convert to iMovie. Tips: You are free to set/adjust output MOV files parameters (Bit rate - high quailty, Frame rate - 60, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. After the conversion, the AVCHD videos could be imported and recognized by Mac iMovie 11 with 60fps highest quailty. And after editing you can upload the best quailty .mts files to Youtube for share. Tips: The Final Mate For Mac support camcorder includes but not limited to Panasonic HDC-TM900,TM90,SD90,HDC-TM700/HS700/SD700, SD60/HS60, DMC-GH2,GH1,GF2,ZS7/TZ10; Sony HDR-CX700, CX550, XR550, XR520, CX350, CX305, CX150,CX360, Alpha NEX-5,DSC-HX5V,; Canon Vixia HF200, HF S100,HG10,HG20,HF R10,HF R11,HF R100.etc If you want to know more about Camocorder , plaease visit the Camcorder column for more information.
Jun 07, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
1,284 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
