Tip & How-To about Cell Phones
Test Mode Information for tdMA models
Enter *3001#12345# and select Field Test (menu option 9 on a 6160), followed by one of three options: Enabled, Enabled+lights, or Disabled. Once selected you must power down the phone and power it up again. To get out of test mode re-enter *3001#12345#, Field Test, Disabled and then power down the phone. Once you power up the phone you may automatically enter field test mode, screen 01 AND/OR you are given a new menu choice of Field Test.
To turn on field test mode select the menu option of Field Test and enter a number between 1 and 7. To turn off field test mode enter number '0'. There are a total of 7 different test mode screens on tdMA models and they may vary somewhat between the different Nokia models. Use the arrow buttons to move between field test screens.
Cell Phones Logo
how do i turn on my hp windows vista bluetooth raido transmitter
To turn your bluetooth on do the following process.
1.Click Start , type wireless into the search field, and then select HP Wireless Assistant from the list.
2. By default, the Status column shows that both of the wireless devices are either on (enabled) or off (disabled). Also, by default, the Action column does not display.
If you want to control one of the wireless devices individually, without affecting the other devices, clickProperties , and then select the Independent controls for installed wireless devices option.
If you have removed the HP Wireless Assistant, it can be reinstalled using the Recovery Manager service.
  1. Click Start , type recovery into the search field, and then select Recovery Manger from the list to open HP Recovery Manager.
  2. Select Advanced options .
  3. Select Software program re-installation and then click Next .
  4. When prompted, click Next .
  5. Select HP Wireless Assistant and then click Next .
Follow the on-screen instructions to complete the installation of the HP Wireless Assistant.
You can verify the device is installed & enabled with Windows Mobility Center.
To turn Bluetooth devices on or off, do the following:
  1. Click Start , type mobility into the search field, and then select Windows Mobility Center from the list to open the Windows Mobility Center. Alternately, press the windows key and the letter x key at the same time.c01577398.gif
  2. Use the drop-down menu items in the Integrated Wireless Devices selection to turn the devices on or off.
    I think the above tips are helpful to you.
    Thank you for using fixya.
Oct 05, 2013 | Radio Communications
how to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
data connection refused
After cancelling the data plan with the wireless service provider, the message Data connection refused appears at the top of the Home screen on the BlackBerry smartphone instead of the branding of the wireless service provider.
This is caused may be you were previously subscribed to a data plan through a wireless service provider, and the BlackBerry smartphone is still configured to attempt to access the data network.
To resolve this issue, you need to turn off the Data Services feature on the BlackBerry smartphone. To perform this, you need to complete the following steps:
  1. From the Home screen, open the Options menu.
  2. Click on Mobile Network or Network.
  3. Set the value of the Data Services field to Off.
  4. Open the menu and select Save.
  5. Return to the Home screen.
  6. Turn the wireless transceiver off and then on again.
To enable (turn on) the wireless transceiver on the BlackBerry device, go to the Home screen and select the Turn Wireless On icon or open Manage Connections and select the wireless connection to be enabled. Once enabled, the icon will display Turn Wireless Off .
To disable (turn off) the wireless transceiver, go to the Home screen and select the Turn Wireless Off icon or open Manage Connections and select the wireless connect to be disabled. Once disabled, the icon will display Turn Wireless On.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
361 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
