Tip & How-To about Computers & Internet
How to recover deleted files in Windows - File Recovery Software
You may have mistakenly deleted a file and you want to recover it. If the file has been deleted from the recycle bin, don't worry! You may be able to recover it. Typically, deleted files are not erased immediately; instead, references to them in the directory structure are removed, and the space they occupy is made available for later overwriting. I will go over steps you can take to try and recover that deleted file.
There are numerous software utilities you can use for file recovery. Some are free and some are paid. I have used and recommend Recuva. You can click the name to download it. This tool is simple to use and does a good job.
Instructions
-Once launched it will prompt you for what type of files to search for. For example, you can search for pictures, videos or all files.
-Next screen it will ask you what location you want to search. You can search the main disk drive or the recycle bin for example.
-After it searches it will display the files it found.
-Click the check box next to the file you want to restore and then click the restore button at the bottom right.
If possible, restore the file to a drive other than the one you are recovering from.
After the recovery process is done you should now be able to view and use your recovered file!
Tip
You can use the Deep Scan option if Recuva does not find the files on the initial scan. It will take longer but may help.
I hope this article helped you out. Be sure to check out my other tech articles by clicking "Tips" in my profile.
Regards,
G33k
Keywords
How to recover files, how to recover deleted files, How to recover files in Windows, how to restore deleted files, how to restore files, how to restore files in Windows, file recovery, recover lost files, recover deleted files, File recovery software, file recovery utility, file recovery software, free file recovery, free file recovery program, free file recovery software
Computers & Internet Logo
How to recover my deleted computer files?
There're many software's available you can used them to recover your data. I personally use this http://goo.gl/hA0DT
Jul 08, 2012 | Computers & Internet
Is there any possibilities to recover the deleted files on the recycle bin after empty the recycle bin? What is the solution?
Yes, it is technically possible to recover any deleted file (Even those removed from the Recycle Bin) by using recovery software.
Check out how to recover deleted files from recycle bin from link blow.
http://www.asoftech.com/articles/how-to-recover-files-deleted-from-recycle-bin.html
Jul 02, 2011 | HP Computers & Internet
i deleted the files in recycle bin
Yes, it is technically possible to recover any deleted file (Even those removed from the Recycle Bin) by using file recovery software.
Check out the data recovery software called asoftech data recovery from link blow.
http://www.asoftech.com/adr/
Apr 20, 2011 | Computers & Internet
recycle bin
Check out the data recovery software from link blow.
Aug 26, 2008 | Kodak EasyShare C360 Digital Camera
1,417 people viewed this tip
David Payne
David Payne
