Tip & How-To about Refrigerators
How to Reset Your Water Filter Light
Amana:
  1. Press and hold the dispenser lock and auto light buttons on the dispenser for 4 seconds until the filter status indicator begins to flash, then release the buttons.
or
  1. Press and hold the dispenser lock and water buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.
or
  1. After replacing the water filter, press and hold the Reset Filter pad for 3 seconds. The Order and Replace indicator lights will blink and then go off when the system is reset.
Brita:
  1. Press firmly and hold start button for 5 to 10 seconds.
  2. Four bars will appear in the display, one after the other, and flash. Do not release the start button until the 4 bars appear and start to flash. If you have difficulty pressing the start button, a capped ballpoint pen may be used to press the button down.
  3. A small flashing dot in the lower right corner shows the indicator is working.
  4. Every 2 weeks a bar automatically disappears. When only 1 bar remains make sure you have a new filter on hand.
  5. After 2 months, when all bars have disappeared, an arrow will flash at the top of the display reminding you to change your filter.
Frigidaire
  1. Press and hold the reset button on the dispenser until the green light flashes (up to 15 seconds).
GE:
  1. Press and hold the reset water filter button on the dispenser for 3 seconds.
or
  1. Press the reset button on the dispenser for 4 to 8 seconds then release.
Hotpoint:
Jenn-Air:
  1. Press and hold the lock and light buttons (lock and water on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.
Kenmore:
  1. Press and hold the button next to the filter light for 10 seconds.
KitchenAide:
  1. Press the light switch 5 times within 10 seconds. If the fridge has a filter button, press and hold it for 5-10 seconds.
LG:
  1. Press and hold the reset button for 3 seconds.
Magic Chef
  1. Press and hold the light and lock pads until the change filter light flashes. (approximately 3 seconds)
Maytag:
or
  1. Press the refrigerator's light switch five times within ten seconds.
Samsung:
  1. Press the ice type and child lock buttons simultaneously for 3 seconds. NOTE: Hold the buttons for only 3 seconds. If you press these 2 buttons simultaneously for 5 seconds, the reset function ceases.
  2. Release the buttons and repeat the same step one more time. The water filter indicator light should turn green.
or
  1. Press and hold the "Alarm/Hold" button for 3 seconds.
or
  1. Press and hold the Fridge and Power Cool buttons for 3 seconds.
Whirlpool:
Refrigerators Logo
How to get alarm to stop blinking after replacing water filter
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Dec 03, 2015 | Fagor FQ9925XUS
I changed my water filter but the filter status light still says to change. How do I get it to go to ok status.
Simply press and hold the dispenser lock and auto light buttons on the dispenser (at the same time) for four (4) seconds until the filter status indicator begins to flash, then release the buttons. On some Amana refrigerators, you need to press the dispenser lock and water buttons for four (4) seconds until the filter status indicator begins to flash, then release the buttons.
Feb 01, 2011 | Amana Refrigerators
How do you reset the water filter light on Model # ED5LHAXWQ00, Serial # HR02227866?
Hi, I found this handy guide:
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Rich
Refrigerator Repair Meridian
Western Appliance Repair
Oct 02, 2010 | Whirlpool Refrigerators
how do i reset the filter light on my refrigerator msd278ge
Also note that
  • Remove the old water filter from your refrigerator by turning the handle counterclockwise and pulling it out of the filter holder. The filter is located in the upper right corner of the refrigerator.
  • Step 2Slide the replacement filter into the filter holder and turn it clockwise.
  • Step 3Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • Good luck......
    Jul 29, 2010 | Maytag MSD2758GEB Side by Side...
    Trying to reset filer light after changing filter-locked up
    Here is a link to the manual for your unit. Copy paste into your browser.
    http://shop.amana.com/assets/pdfs/literature/12591321.PDF
    Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
    There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
    DISPENSER LOCK
    (SELECT MODELS)
    This feature prevents ice or water from
    being dispensed.
    To lock dispenser:
    ➢ Press and hold DISPENSER LOCK
    button for 3 seconds. A green
    indicator light above button confirms
    dispenser is locked.
    To unlock dispenser:
    ➢ Hold DISPENSER LOCK button for 3
    seconds. Green indicator light above
    button will go out.
    Filter reset
    The filter status indicator light
    serves as a reminder to replace the
    water filter. A green light indicates that
    the filter is in good condition. A red light
    indicates the filter should be changed.
    Once light turns red, it will remain red
    until function is reset.
    To reset indicator:
    ➢ Press and hold both DISPENSER
    LOCK and WATER buttons
    simultaneously for 4 seconds. The
    green filter status indicator light will
    flash 3 times when the function has
    successfully reset.
    Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
    893 people viewed this tip
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
