Tip & How-To about Heating & Cooling
How to Reset Your Air Conditioner Filter Light
Cabin Air Conditioner:
  1. Press and hold down the Off button for 4 seconds.
Carrier Air Conditioner:
  1. Press the Reset Filter button to reset the timer that calculates the next air filter change after you have inspected / cleaned the indoor return air filter.
Daikan Air Conditioner:
  1. Press the Filter Clean Reset button to reset the CLEAN FILTER INDICATOR after you have inspected / cleaned the indoor return air filter.
Frigidaire Air Conditioner:
  1. To reset after cleaning the filter, press the "Filter Reset" button and the light will go off.
GE Air Conditioner:
  1. Turn the air conditioner OFF and unplug it.
  2. The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter.
  3. After cleaning, replace the filter and plug the air conditioner back in.
Honeywell Air Conditioner:
  1. Press and hold the i button until the timer is displayed, followed by pressing the Up Arrow button (next to the Wake button)
  2. Press the Run Program button.
Kenmore Air Conditioner:
  1. To reset the filter indicator, press and hold the filter reset button for 3 seconds.
Lexus Air Conditioner:
  1. Without having foot on the brake, press the Start button twice to get to the IG-ON position.
  2. Then press and hold the "hard" OFF button next to the "hard" Auto button. Hold the OFF button for approx 5 seconds and you hear several beeps.
or
  1. Turn the engine switch to IG-ON mode.
  2. Push and hold the A/C OFF button for more than 4 seconds.
Lexus 2008 Air Conditioner:
  1. Push the "INFO" button & touch "Maintenance".
  2. Touch the desired button Delete All: To cancel all conditions which have been input or Reset All: To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.
  3. Input the Notice of Date: The next maintenance date must be input.
  4. Now input the Notice of Distance: The driving distance until the next maintenance check.
  5. Delete: To cancel the date and distance conditions.
  6. Reset: To reset the date and distance conditions.
  7. Touch "OK" The screen returns to the "Maintenance screen.
Lincoln LS 2001 Air Conditioner:
  1. Press and hold the setup button above the radio until it says system check. NOTE: All the doors must be closed.
  2. Watch the system check when it goes to A/C filter hit the reset button.
  3. Hold down the reset button to confirm.
Lincoln LS 2003 Air Conditioner:
  1. Press the STATUS control to access the System Check function, the message center will display A/C FILTER XX% RESET FOR NEW.
  2. Press and hold the RESET control to set to 100%.
Lincoln LS 2005 Air Conditioner:
  1. Insert the key and turn the ignition to "Run" or "On." It is not necessary to start the engine.
  2. Press the "Status" button above the radio until the system display changes to "AC Filter."
  3. Press and hold "Reset" above the radio. The system will beep and the "AC Filter" display resets to "100%."
Maytag Air Conditioner:
  1. Press the "Fan" button 2 times, then press the "Mode" button 1 time and it will reset.
Whirlpool Air Conditioner:
  1. Push in the filter reset on the remote using a straightened out paper clip or similar.
or
  1. On the control panel, press and hold the Mode and the Up Temp Arrow buttons for 6 seconds.
or
  1. After having cleaned the filter just press the reset button located on the indoor unit behind the front panel to interrupt the flashing of the filter monitor indicator.
Heating & Cooling Logo
how do i fix E1 error
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2 Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditioner. Move to the next step if the LCD continues to display the E1 error code.
  • 3 Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4 Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor responsible for detecting room temperature may be defective.
  • Jun 10, 2014 | Amana Acd12ke-e Window Air Conditioner
    I am looking for what an error code is: B with a 12 under it.
    Code B12 is your 10,000 miles check up:
    B: oil & filter change
    1: tire rotation
    2: engine air filter, cabin air filter change
    Reset Meter:
    1: turn car to ON (II)
    2: press sel/res button until oil life % is displayed
    3: press & hold sel/res button until oil life blinks (10 seconds)
    4: release button
    5: press & hold sel/res button until oil life shows 100 (5 seconds)
    Hope this helps (remember to rate this answer). Good luck.
    Feb 23, 2011 | Honda Odyssey Cars & Trucks
    Replace air filter warning light to reset?
    1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
    If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
    *Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
    Sep 30, 2010 | Filter Queen Defender Air Purifier
    it says reset filter
    Reset the filter timer. (1) Turn on the projector. While the projector running, press the MENU button to open the menu. (2) Choose the “OPTION” on the menu using the up/down button, then press the right button or ENTER button. (3) Choose the “FILTER TIME” using the up/down button, then press and hold the right button of projector or the RESET button of remote control for 3 seconds. (4) Choose the “RESET” using the up button.
    Dec 04, 2008 | Office Equipment & Supplies
    2,908 people viewed this tip
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
