Tip & How-To about Computers & Internet
How to deal with different multiple partitions on a large capacity hard drive
There are many people who wish that they have the maximum storage capacity available in their hard disk.
The more space you have these days, makes you urge for some more .
Therefore when your satisfaction was with a 250 GB hard drive , in some time you would feel a 500 GB hard disk is something which you require.
No wonder due to increase software technology and their huge you will need a large storage space.It's not surprising to see software in multiple GBs for e.g.a Adobe suite would take approx around 5 + Gbs of space depending on the applications you want.
Therefore the best way to manage your hard disk drive is as follows :-
1. Create as much partitions as you require , and don't be lazy about it. :- Many people as a result of excitement just want to go ahead with the windows installation or an operating system's installation , without considering the hard disk state, i.e. without actually partitioning the hard disk and then going ahead with the installation of the operating system.
However this attitude does not help when you have the only partition that you trusted is damaged , not everyone knows damage recovery and may end up believing that he has lost all valuable data and will reinstall the operating system after a full format.
2.
Separate the partitions for Operating systems and your personal data :- Even though you have options like my documents and my pictures in your root drive where the operating system has been installed , it's always better to keep your personal files in another partition besides the root drive , as you never know when the root drive would be affected by virus and your master boot record would be damaged , and then you would end up formatting your drive.
3.
Create partitions based on the sorting of your personal /official files :-
If you want to have multiple partitions have them on the basis of your work. For instance , it's always better to have a separate partition for your official work so that you can have a timely backup and don't mix it up with your personal files be it your home videos or pictures.
4.
Name them such that you can identify them easily :-
How many times has it happened that you are searching for something by opening up the different partitions that exist and then getting frustrated as a result ? You know the data is there, but you just don't know where. Therefore the solution to this problem would be to rename the partition itself in a way that when you want to search for some data , you know which partition you want to search for the data.
Hope this helps ..:)
Computers & Internet Logo
What is the maximum Storage space that a IBM x226 Server can be scaled
6 x 300GB (largest available U320 SCSI HDD Capacity) = 1800 GB
Mar 26, 2015 | IBM Computers & Internet
I have HP Pavilion dv6500 laptop with 120 gb hard drive. Are there problem issues upgrading to a 500gb or larger hard drive?
No there is no problem in upgrading the hard drive.
You can upgrade it as much as your system supports it.First check your system capacity of expansion of the hard drive's space.You must know the maximum capacity of the hard disk on your system .
Thanks.
Have a great day.
Sep 17, 2010 | Computers & Internet
I have a SAMSUNG HM320JI (320GB). After loading Windows XP Proffesional, I found that the C Drive only has 116 GB assigned t it and the hard disk proerties (in Device Manager) shows 117 GB in "Unallocated Space". how can I increase the capacity of the C drive?
To increase the capacity of formatted disk space on your computer, you will need to go to Disk Management. This can be found under the Control Panel, Administrative Tools, and Computer Management. Under the Control Panel's category view, Administrative Tools can be found under Performance and Maintenance.
On the left pane, you will see several options. Disk Management is available under Storage. You will definitely be able to format your unpartitioned space here. However, you may or may not be able to expand your C Drive space with this option, it may end up becoming a D Drive, or another letter of your choosing.
If this does not work to extend your C Drive space and adding a second drive letter is not an option for you, you can either reformat to receive the entire available disk space, or, if you prefer, there is commercial (such as Partition Magic), and potentially free, software available to perform this.
Please let me know if I can be of any additional help. Thanks!
Aug 11, 2010 | Samsung Computers & Internet
hard drive space
Well I'm gonna need more information i.e. What operating system are using with the device etc. And also check disk management(i assume u are using either windows 2000 or XP) to see how much total disk space is available on the device. Disk Management(Right Click on My Computer then click Manage. On the left pane expand Storage then got to(click on) disk management. When there u'll see all the disk connected to your system at the time on the right pane. Look for your disk then scroll down and you'll see how much is available and how much is used!
Apr 18, 2007 | LaCie (300952U) 300 GB Hard Drive
142 people viewed this tip
David Payne
David Payne
